Wing vs wingless??
Old Oct 7, 2009 | 11:02 AM
RyuEvoIX's Avatar
When I was trapping in the low to mid 120's I noticed a 1mph increase by removing the wing. I'd imagine at around 113mph removing the wing should help at least .5mph if not more. My .02
Old Oct 7, 2009 | 11:41 AM
vito's Avatar
in any case, it looks better with a wing.. :P
Old Oct 7, 2009 | 01:36 PM
project_skyline's Avatar
I figured as much. I'll just leave it on then till im trapping in the 150 range. lol
Old Oct 7, 2009 | 05:03 PM
mrdevo's Avatar
Someone actually tested this a while back and I believe they noticed an improvement in the mph. Not sure what he was trapping though..
Old Oct 8, 2009 | 06:33 AM
FL_SilverEvo8's Avatar
But no improvement on lower times?
Old Oct 8, 2009 | 03:25 PM
RyuEvoIX's Avatar
higher mph = quicker ET given all other variables are the same.
Old Oct 9, 2009 | 12:37 PM
dambikeracer's Avatar
12.1 with wing, 11.8 without! That's was the only thing I changed. Trap speeds went from 110 to 114.
Old Oct 9, 2009 | 01:17 PM
neonglh's Avatar
Nice, but there had to be more to it. Buschur did a bunch of testing, and found almost no difference. I know that Ryu is probably right, where it maybe 1 mph on a 120+ trapping car. If you look at all of the FAST Evos, most don't have wings.
I doubt that you dropped .3 and 4 mph just from the wing, it could have been other factors like temperature, your 60' time, etc.. I guess if you had 20 12.1 passes in a row, you take the wing off, then run 11.8 that same day, then I would be a believer
Old Oct 9, 2009 | 01:22 PM
stwhollywood's Avatar
functionally the wing is worth keeping on, i recently became a huge fan of wingless with the JDM rear and the voltex rear diffuser. for sure what im doing the day i get my car back from the shop. just my .02
Old Oct 9, 2009 | 04:50 PM
I was not on the same day, that is for sure but I did make 8 or 9 passes at 12.1, then I went out one week later and was running 12.0-12.2. Then I jumped down to 11.8 three time in a row.
Old Oct 9, 2009 | 05:11 PM
kouzman's Avatar
Guys!
since the wing holds the car on the road especially at high speed, in order to achieve that it has to create downforce... Downforce can "steal" mph...
Two examples:
- The new hyper exotic the Murcielago SV is offered with a small wing and a large wing... The large wing has like 10 mph less top speed...
- Remember the Ford Escort RS Cosworth from the early 90s? It had a monstrous wing that in stock trim the car couldn't top more than 140-145mph i believe. People who removed the wing could easily see 160mph!!!!
In other words, as the speed increases the drag created by the wing is greater, thus the impact on mph... Maybe we dont see a change at 110mph, but at 130mph or even higher it could help...
Old Oct 10, 2009 | 04:28 AM
Cyloc's Avatar
I think the info he is looking for is about how much downforce does it create on the car.
The evo wing actually creates a good amount of downforce. From info that i had recieved from mitsu a while back, the wing basically adds 40 lbs of down force for every 50 miles per hour you do. So at 100 you have about 80 lbs sitting on the *** end of the car.
The reason I had got this info was due to setting up the awd dynojet in tampa for big valley performance.
So if the theory stands correct you will gain under 1mph and loose about 0.08 sec.
Old Oct 10, 2009 | 04:51 AM
Mulholland0132's Avatar
Originally Posted by 97TSiAWD
Evos weren't designed as drag race cars. And Evo RS owners seem to do okay without the wing.
Well stated sir!
Old Oct 10, 2009 | 07:23 PM
hoof hearted's Avatar
Originally Posted by 2003evo8
its their for a reason they just dont put things on cars to waste money
I have a question for you.... When's the LAST TIME YOU USED YOUR REAR WINDOW WASHER/WIPER???????..........
'Nuff said.
Old Oct 12, 2009 | 05:00 AM
Is this for real? Can someone 2nd this. Thanks for the info.
