Speedtech/Dave Stock New World record
A big shout out to Craig from Sparktech who has been great to deal with and has bent over backwards to help us out! And finally a big thankyou to AMS for setting the bar so high in the first place. It wouldn't be much fun if there was nothing to aim for, and Dave had your record in his sights for quite some time. Hopefully this might inspire you guys to bring the car out and try to run quicker.
Andre
Andre
+1 for the consistency of this car.
It's one thing to break a record, but it's a whole other league to run consistent 8's like this car seems to be doing. Has this car been on the same motor so far since it was first built?
And that is just mad that they haven't pushed more than 40 psi yet. With a big T4 turbo like they are running, I'm assuming they can go way up in boost?
It's apparant that the guys from NZ know their sh*t
By the way hope the guys from NZ STM see this but i was just wondering what your team member is doing when he stages you and holds something up to the winshield???
Is that a reminder for the driver before he makes his pass or is he wiping something on the windshield?
Thanks and congrats again!
I believe a very detailed mod list has been posted either here on in another thread when it ran 8's a few weeks ago i don't think they have much to hide cuz most of us wouldn't even have the funds to gather up the parts these guys run
Post # 42
https://www.evolutionm.net/forums/dr...163-mph-3.html
Engine:
Mitsubishi 4G63 Turbo
2.2 Litre Tomei billet crankshaft
Custom billet aluminium conrods
JE Pistons (Custom STM spec)
STM competition balance shaft removal kit
Baffled alloy sump
HKS head gasket with STM O-Ring kit
STM Drag spec head studs
Ported cylinder head
STM Drag spec cams
Solid lifters
Competition double valve spring kit
Oversize stainless valves
HKS adjustable cam gears
HKS cambelt
Mechanical cambelt tensioner
Hypertune plenum with 90mm throttle body
Turbocharger:
Garrett GT45 based turbo with Tial Sport exhaust housing
Turbosmart 60mm wastegate
Custom stainless STM headers with full merge collector
100mm stainless exhaust
100mm intercooler
80mm aluminium intercooler plumbing
Turbosmart raceport blow off valve
Drivetrain:
PPG 4 speed dog engagement gearbox
Ikeya Sequential shifter with custom air shifter system
Quarter Master triple plate clutch on custom flywheel
DSS stage 5 axle kit (front and rear)
STM transfer case
Wheels:
15x7” Rays TE37 rims
24.5 x 8 x 15” MT drag slicks
Brakes:
Lightweight Wilwood 4 piston callipers front
Lightweight Wilwood 2 piston callipers rear
Lightweight scalloped rotors front and rear
Hydraulic handbrake
ABS removal
Linelock system for staging
Electronics:
Motec M400 ECU
Motec SDL sport dash logger
Motec E888 expansion unit
M&W PRO Drag 4 CDI
Sparktech CDI coil-on-plug system
Fuel System:
12 Litre fuel cell
Twin SX 1000 HP fuel pumps
SX fuel pressure regulator
HKS fuel rail
1600 cc injectors
Body:
Lightweight fibreglass doors
Modified front chassis
Fibreglass bootlid
6 point NZDRA spec rollcage
Racetech seat
5 point harness
We have run upto 42 psi on the dyno, and with the large GT45 turbo it is safe to say that it will continue making more power to well over 50 psi!
Too many shops make out that this sort of build is a black art, and shroud it in mystery. We believe nothing is further from the truth. We had a design brief, selected parts to meet the design aims, and then built the car. The results speak for themselves.
Andre
