Best 60' on Hoosier QTP
Old Mar 25, 2010 | 07:17 PM
kouzman's Avatar
Whats a usual 2step for these tires?
6000rpm?
6500rpm?
7000rpm?
Of course it depends if you are retarding timing from the AEM in order to build boost, but can someone share ballparl figures?
What about tire pressure? 20psi? 18psi? 15psi? lower? same front and back?
Old Mar 25, 2010 | 08:18 PM
bsmart82's Avatar
I have these in 26x9.5x16 on Rota Slipstreams on my Talon. I pulled a 1.61 60' on the 4th ever launch with a 6k 2-step and anti-lag building 12psi boost. I hope to be in the high 1.4/low 1.5 range with my new Talon(automatic).
Old Mar 25, 2010 | 08:38 PM
aka.ralliart15's Avatar
Cwill went 1.39 60' on DOTs...he burns out all 4 tires at the beginning.
Hows it going Will?
Old Mar 26, 2010 | 11:16 AM
TALONGT's Avatar
Forgot to mention my first pass on the 16" QTp and Zero track temperatures in late fall up in Canada netted me a 1.59 60ft.
Old Mar 26, 2010 | 02:09 PM
neonglh's Avatar
I was cutting consistent high 1.4xx 60' with the 26" QTP. I think my best was a 1.480, and you have to remember, my car was only making 356/356, so I didn't have much more power to get a better 60'.
--mark
Old Mar 26, 2010 | 02:43 PM
TALONGT's Avatar
--mark
Were you running tubes? What tire pressure?
Old Mar 26, 2010 | 08:09 PM
lillev23's Avatar
Hows it going Will?
Everythings been going pretty good man. Just trying to finish this car up. I made alot of changes this year, so I hope I can get everything together and make some good passes down the track.
Old Mar 26, 2010 | 08:27 PM
really? thats awesome, you got another turbo right?
Old Mar 27, 2010 | 10:04 AM
lillev23's Avatar
Yep. look at the subliminal message in my signature. lol
Old Mar 27, 2010 | 10:09 AM
lol nice, I think i can guess...good luck
Old Mar 29, 2010 | 06:09 AM
neonglh's Avatar
No tubes. The tire pressure was probably around 20 psi or so, but I truthfully don't remember. I did a healthy burnout before each pass though!
--mark
Old Mar 31, 2010 | 05:27 PM
CWiLL's Avatar
Yea I've cut a lot of 1.40s and 2 1.39s on 16in qtps
Old Apr 1, 2010 | 01:43 AM
Evokid03's Avatar
^^ What tire pressure did you have them set to CWill?
Old Apr 2, 2010 | 07:38 AM
CWiLL's Avatar
Originally Posted by evokid03
^^ what tire pressure did you have them set to cwill?
13 14
Old Apr 2, 2010 | 07:39 AM
CWiLL's Avatar
6000rpm?
6500rpm?
7000rpm?
13 14, 7k standard 2step building 7 to 9 psi off boost.
