Cages NHRA Cert?
Old May 9, 2010 | 11:13 AM
Anarchy99's Avatar
Autopower cage is not legal. No cage is NHRA legal that you are not welding together.
Old May 9, 2010 | 01:36 PM
Most-Wanted's Avatar
Originally Posted by sho669
sorry don't get the web lingo there just building another fast evo that see's street duty almost everyday. want it to be safe for myself and my familly and be built to a higher level than some that I have seen running the same e.t.'s
i'll probably post a thread when the cage is done, should be pretty cool stuff but may be a little extreme for some.
Sorry, but no NHRA spec'd cage is really safe for the kids and family unless everyone is wearing helmets in my opinion... Whether to cage or not has been a very long debate for many. I do not recommend it unless you are strictly drag racing the car. Not to mention they are a real big PITA. My honest opinion is if want to cage it have the family follow you in another vehicle. A caged car is no place for kids...
That being said. Just to have a car certified costs around $200 if memory serves me correct and it has to be perfect. There are so many requirements you wouldnt believe it. Then if the track is that hard on tech you need to do the research on seatbelts, seats, etc. Things like if you are running an aftermarket seat if its not certified it needs to be bolted to the cage. Seatbelt mounts need to be in proper locations. Its not weld a 6 point in and be done... The work is extensive... Not trying to be a dk, just trying to give you some insight to what your getting yourself into. Resale is a major issue as well...
Old May 9, 2010 | 01:37 PM
And this is what it looks like when you pay thousands of dollars to have it done right and its a fully certified NHRA cage. If your going to do it, you better do it right... Most people usedto charge $150 a point for refrence on cost. The cost of material has gone up since then so it may fluctuate... The front halo is also another consideration. If your gonna go in and tear the interior out to do the cage you might as well do the front so you are certified for 8.50. A 6 point is very limiting... I'd have to do a quick check but I believe the cutoff is 9.99. Man its been awhile since I've been in the rule book. But if you want to run 9's you better reed the book to be safe so you dont find yourself redoing stuff...
Old May 9, 2010 | 02:09 PM
sho669's Avatar
Oh yeah been going through the rulebook and making calls for sure the cage deff is gonna be a big PITA but I am spending the time and research to do it the right way.
I like how the rear bars route in your pics, do you have any of the trunk mounting? If you would PM me any pics ya have that would be good to show my fab guy.
The car isn't going to be daily transportation for the kids, just an ocasional romp around town or to the store, just like the idea of the rear seat staying in for a "street" appearance. Interior is coming apart as needed and front bars are going through the dash as needed for certs. There are a couple new rules reguarding cages that came out this year as well about seat mounting and belts also.
Thanks for the input Most-Wanted that build was a monster! It inspired my build for sure!
Old May 10, 2010 | 02:54 PM
PATRICK B.'s Avatar
Just to add and remind others it's not only the 9.99 to be aware of but also a trap speed greater than 135 mph when considering a full cert'd 8.50 cage
Brian's car is a perfect example of quality work that's necessary to pass inspection KUDOS again Brian!
FYI it may be worth contacting you local NHRA official that will do the certification as i have heard news that in order to mount the "D" bars properly you must run a horizontal bar connecting the lower bars of the main hoop and then have the "D" bars mounted to it rather than a 6x6 plate on the floor board.
I have yet to complete the remainder of the cage for my car as i am still unsure about going further w/ this chassis.
Here's a pic of my trunk bars:
Old May 10, 2010 | 06:51 PM
sho669's Avatar
Yeah it's a long process for sure but I want to run the car a lot so I'll do what I have to do. This car is opening a lot of eyes at my local track, people think it insane that a 4cyl car thats basically stock can run with their "built" race cars just wait untill the prepped engine and the new turbo go on!
Building Evo's is a lot different than building Camaro's and Mustang's for sure!
Old May 10, 2010 | 11:08 PM
No problem and thanks for the props guys. Here is a pic of the rear bars during the build process. They are the same as Patrick's. Good luck on the build...
Old May 11, 2010 | 08:11 AM
sho669's Avatar
Thanks for the pics guys! Looks good!
4g63girl
Jan 23, 2015 12:56 PM
george3
Jun 24, 2012 02:02 PM
thedragon
Jan 23, 2008 01:38 PM
beast21
19
Nov 30, 2006 08:21 PM
EVO-Bill
Nov 8, 2003 12:19 PM
