Trouble reaching target boost at the track only
not in a MBC it never does.. An FP red can hold 30psi flat as a table to 7500 with a properly tuned electronic boost controller, with an mbc you need to crank it up to see the same peak pressure rowing through the gears as you would from a low rpm roll on the street, although different setups will have less of an effect then others. Also Binh has a T4 twin scroll housing.
Which top three ebc's would you recommend I start reading about while I continue my research?
Thanks
I like grimspeed,perrin, and gm.. They all work pretty well.
It SHOULD be, unless that amount of boost is causing too much backpressure for that TS housing, but I wouldn't imagine that happening at less then 30psi but its probably pretty close.
You know what i was just thinking? The car used to do the same thing with the stock turbo, milder cams, etc etc etc. Hmmmm, mass air sensor problem maybe?? I changed out nearly everything when i put the red and meth in
Merlion
Cobb AccessPORT
Dec 2, 2015 07:33 AM
