9.79 @ 152 MPH on All Season tires
Old Aug 23, 2010 | 10:06 AM
Flyin EVO 2's Avatar
At the Shootout I ran into head gasket issues from the car previously overheating due to a faulty hose clamp. I was trying to set up my 2 stage boost controler and 2 step so I could just mash the throttle and let the car do the work. Keep in mind this is on 225/50 16 Sumitomo all season tires. Well it didn't work out so good, and the best pass was a crappy 10.20@ 151 mph with a sucky 1.89 60 ft.
As soon as I got home I pulled the head, had it cleaned up and threw a new MLS gasket in. Then I looked at the logs, made some more adjustments and decided to drive the car as if it was a FWD to get it to leave as smooth and hard as possible. At 38 psi on E85 with the all season tires it went 9.79 @ 152 mph with a 1.61 60 ft. On the next pass I made some more tweaks and decided to try and launch a little harder, the T-case didn't like that one and snapped like a twig. The crazy thing is it snapped as soon as I let out the clutch and still went 1.7 in the 60 ft. I know with a built T-case and axles 1.5's on these tires won't be hard to do. I also can run another 7 psi of boost once I have a drive train that can handle it.
Thanks to www.douglasautoworks.com for all of there hard work this season.
http://i39.photobucket.com/albums/e1...phslip8-10.jpg
1994 EVO 2 LHD conversion
Full interior, only A/C removed
2890 lbs with driver
E85 tuned by Yusuf Begic of Douglas Autoworks Roselle, IL
Autronic ECM
ARC 2 ignition box
1600cc bosch fuel injectors
Aeromotive A1000 with 40 amp Kenny Bell Boost-A-Pump
Douglas Autoworks 110 amp racing alternator
2.0 Block built by Class One in Freeport, IL
Arias 9.5 to 1 pistons
Crower rods
Freshened up this season by Douglas Autoworks (new rings and bearings)
1G ported head with Kiggly Racing valve springs and HLA restrictor
FP 5r in and ex cams
Borg Warner S400 74mm T4 1.10 divided
Old Aug 23, 2010 | 12:03 PM
Boomba Racing's Avatar
Nice work my friend, I heard from Tim Zimmer you were able to break a t-case on street tires Thats nutts
Devin
Old Aug 23, 2010 | 12:17 PM
06MREvo's Avatar
Ridiculous for all season tires...very nice job...
Old Aug 24, 2010 | 02:02 AM
Thanks guys. Devin, I never thought it would even try to hook up that good on all season tires. I know mid to high 9's isn't too impressive nowadays, but in a full interior real street tire car it's not at easy as it seems.
Old Aug 28, 2010 | 10:18 AM
jason900rr's Avatar
nice work! wish i could get mine to hook up. last year on winter tires and less HP and with issues, i ran a 11.6. now im at 10psi more(40psi),E85 and issues solved with street tires and could only get a 11.7
evodude32
Feb 18, 2012 07:23 AM
evodude32
Feb 17, 2012 07:44 PM
DouglasAutoworks
Jan 26, 2012 12:57 PM
DouglasAutoworks
Mar 11, 2011 10:52 AM
DouglasAutoworks
For Sale - Wheels / Tires
Mar 11, 2011 08:04 AM
