A disappointing 10sec pass, HTA green e85
Old May 23, 2011 | 12:09 PM
_des_'s Avatar
My previous Thread https://www.evolutionm.net/forums/dr...0sec-pass.html
Went to IFO yesterday and wasn't happy
I ran a best of 10.99@122mph. My previous best was 10.95@125mph.
We were tunning the car the night before IFO and we discovered I was out of Injectors! 1050cc defiantly wasn't cutting it for e85. So I could only run 27-28psi dropping down to 21psi at redline
When the 10.95 was ran it was on a maf, since then the car has a Buschur Short route UCIP Tial BOV and Mini Battery. ETS LICP,new custom Intake 4" all the way to a reducer 3.25" with a 4" inlet K&N Filter 9" Diameter, Omni 4 bar, Grimspeed 3 port Boost controller, Spoolinup COP setup, and a ported hotside from MAP.
Completly didn't expect it to max out the injectors tho, Previous IDC were at 83% at 30+psi. Currently the IDC were hitting 118% at lower boost
EDIT: O ya something I completely forgot to add. It was 94 degrees then, The track temp was 145...
I have some vidoes and pics that I will post up soon.
Planning on getting bigger injectors and try again
Old May 23, 2011 | 12:21 PM
SyZyGy1394's Avatar
Are you on a single walbro? If so, then you might actually be out of pump before the injectors. I.e overrunning the injectors to compensate for the falling fuel pressure...
Old May 23, 2011 | 12:34 PM
_des_'s Avatar
Have a buschur double pumper.
Old May 23, 2011 | 02:14 PM
bambooi's Avatar
What kind of power are you making on virtual dyno?
Old May 23, 2011 | 02:23 PM
SOEuro's Avatar
LOL,Get some 1250s or better,Where are you getting E85 ,around there. Ive got the FIC 1250s seeing 60% at the same boost levels
Old May 23, 2011 | 07:40 PM
_des_'s Avatar
on the virtual dyno It was around 510hp and 420tq, I think lol I'll double check. This was spikin to 27psi dropping to 21psi @ redline.
I just finished using the remainder of my e85 drum. Had to travel 40 miles past Montgomery to get some.. Refilled the drum
I think I have a pretty efficient setup that's why it's needing more fuel. I have a feeling it was the ported hot side from map. Really needed alot more fuel to get it right.
Old May 25, 2011 | 02:34 PM
bambooi's Avatar
Did you double check for me?
Old May 25, 2011 | 02:44 PM
TalonFiero's Avatar
Nice driving!
Old May 25, 2011 | 02:46 PM
SOEuro's Avatar
good stuff youve got alot faster since the last time ive seen you
what wheel setup are you on now?
Old May 25, 2011 | 02:53 PM
Boltz.'s Avatar
FCOTM Winner
Judging from your two slips I see two things that slowed your new time down (other than maxing the injectors). Slightly slower launch and shift knock into fourth gear.
Old May 25, 2011 | 02:57 PM
_des_'s Avatar
Checking now
Originally Posted by TalonFiero
Nice driving!
Thanks, About to order injectors this friday. woot woot hopefully another lower 10 second pass.
Haha Ya I remember when I was calling you asking you stupid questions. You were probably like "man this kid wont leave me alone" lol
On the track I am running fd rx7 26x9.5x16 Hoosier QTP. Required 25mm spacer in the front. My two step was just simply to low, I couldn't get an aggressive launch.
Old May 25, 2011 | 03:08 PM
SOEuro's Avatar
no way man, im always down to help
i dont know much about DSMs,but can you swap over those FIC 2150s to the evo?
Old May 25, 2011 | 03:18 PM
_des_'s Avatar
Haha great to hear bro!
They are the same but i refuse to take parts off of the talon!
Old May 25, 2011 | 03:36 PM
SOEuro's Avatar
o COMEON man,is that talon even running?
that would solve all your injector issues
Old May 26, 2011 | 11:20 AM
_des_'s Avatar
I just confirmed it with my tuner, We were only hitting 25psi.
I didn't drop the tire pressure as much as last time because I was already having issues bogging(two step wasn't set up right) probably why 60ft wasn't the best. It was getting occasional shift knock in fourth also. Just the lack of fuel
The talon is close! lol I'm not taking parts off the "race car"
