Clutch Preload 101 how-to
Old May 26, 2011 | 03:51 PM
  #46
pinoy6969's Avatar
what do u mean by ebrake engange barely?sry...i just tried it...i still smelled the clutch..idk what im doing wrong
Old May 26, 2011 | 05:27 PM
  #47
evodude32's Avatar
sigh..... You need to watch the video again, and read everything in this thread. It's been discussed over and over.
step one: pull up ebrake holding the button in so the ebrake does not lock on you Pull the ebrake up as far as you can..
step two: bring the clutch out till it BARELY starts to grab
step three: hit the 2step by going full throttle ***NOTE: stock ecu cars this will only work on 03-04 evo's since the 2step feature in via vehicle speed, 05-06 evos with stock ecu's won't work as the 2step switch is only with the clutch fully to the floor.. Unless it can be adjusted via vehicle speed through ecuflash for 05+ evo's
step four: release the ebrake
step five: release the clutch out completely the second you feel your car move.
Now, if you trying to do this on a single disc clutch, it won't work as well. You will burn the clutch up quicker. This pre-load method is more towards cars with twin or triple plate clutches as I have stated in the video and in here as well.
Old May 26, 2011 | 05:43 PM
  #48
pinoy6969's Avatar
what do u mean by barely??alright ill watch again and try
Old May 26, 2011 | 06:07 PM
  #49
evodude32's Avatar
Dude, I've explained it as best as I could, not only in the video but here as well. I don't know of any other way of explaining this to you. Sorry man, not trying to be rude, but seriously (insert face palm gif here lol)
I'm not sure what your not understanding about the meaning of "barely". Bring the clutch out till it barely starts to grab with the e-brake up all the way to hold the car from moving. Bring it up on the 2step then release the e-brake, car will move, from there just let the clutch out and off you go.
Old May 26, 2011 | 07:55 PM
  #50
mrboost05's Avatar
good video of emery getting busy preloading using the ebrake click around 46 secs
http://www.youtube.com/watch?v=dTW-b...eature=related
Old May 26, 2011 | 08:05 PM
  #51
wizzo 8's Avatar
Ok I might try it this year. After seeing some video it looks promising. Its just more stuff to remember to do.
Old May 27, 2011 | 06:31 AM
  #52
Boltz.'s Avatar
FCOTM Winner
It is, also makes launching easier. Lemme know if you want some help.
Old May 29, 2011 | 03:37 PM
  #53
ant_turbo's Avatar
I hav been doing this since I have bought my evo 9 back in 06,,, Works great..
Here's a video in action at the 1/8 track,, You can actually hear as a I pull up the e-brake and see,,, about 12/15psi Tephra7 Launch map,
http://www.youtube.com/watch?v=IpPlPtSlJtU
Old May 30, 2011 | 06:39 PM
  #54
project_skyline's Avatar
Personally I don't feel like you need to pre-load a single disc organic clutch. 4 or 6 puck it works but not street disc.
Not sure why its so hard to grasp though but maybe thats cause I know how to do it lol.
Great write up btw!
Old May 30, 2011 | 06:58 PM
  #55
evodude32's Avatar
Great write up btw!
I agree with you, single disc clutch you shouldn't need to pre-load as those disc are fairly soft on launches, they always slip a tad regardless what you do.
Old May 31, 2011 | 09:17 AM
  #56
Black Momba's Avatar
i like that last video 1.59 60ft gives you good times no matter what power level you are at
Old Jun 14, 2011 | 11:58 AM
  #57
PATRICK B.'s Avatar
Just thought i'd bump the thread and add a little vid from some passes made last Sun.
I'll have a seperate thread w/ results from the race that turned into TNT day lol.
I had the front & rear seats out along with the carpet as i need to finish painting some parts of the cage but it worked nicely to be able to see my legs and all that goes on.
Since it turned into TNT i decidied to really practice on my launch technique and got into a nice rythm.
Here's 1 of the better launches (the shifts needed some work but weren't all that bad):
Hope this helps a little.........
http://www.youtube.com/watch?v=vSkYQe8Smso
Old Jun 14, 2011 | 12:15 PM
  #58
06MREvo's Avatar
^^^Video set to private??
Old Jun 14, 2011 | 12:23 PM
  #59
PATRICK B.'s Avatar
My bad try it again
Old Jun 14, 2011 | 12:30 PM
  #60
06MREvo's Avatar
Originally Posted by PATRICK B.
My bad try it again
haha...Just watched it in your other thread, nice!
