What width and offset 15" Rota wheel to get
Old Jun 29, 2011 | 09:39 PM
familymr's Avatar
I am about to order my drag wheels. I need to find out what width and offset you guys are using. I am going to get 15 inch slipstreams. Also will i need spacers. Thanks for the help
Old May 10, 2013 | 05:12 PM
maknuge's Avatar
Bump. Need the same answer. Thanks.
Old May 10, 2013 | 05:13 PM
maknuge's Avatar
I have a small front brake kit
Old May 11, 2013 | 07:38 AM
PATRICK B.'s Avatar
I picked up my 15" Slipstreams years ago and back then they didn't have many sizes locally so what i ended up with is a slight bit different than most which affects what size spacer you end up having to use.
Also depends on what small brake set-up you run whether it is Willwood, Brakeman, or even small Mitsu set-ups.
What i run are 15x7.5 +40 offset and i run a 20mm spacer on the front at the moment i don't run a spacer in the rear but was thinking of doing so when i did the longer arp studs back there but haven't yet and it looks pretty good with the 24.5" M&H slicks
I believe what most people run are 15x7 +35offset and typically a 15mm or 20mm spacer.
BTW i may have my set-up for sale soon and i also have a set of 26" MT ET Drags if you need the extra tire diameter for you gearing lmk if interested
Old May 13, 2013 | 07:22 AM
maknuge's Avatar
I have the stm drag brake kit. I am on stock gearing so I would want 26" slicks. I like your stance. What suspension you on?
Old May 13, 2013 | 07:29 AM
badev0's Avatar
I run the 15x7 + 40 slipstreams with STM small brake kit up front.. 10 mm spacer, stock rear brakes, stock suspension. I would recommend the 15x7 over 7.5 (at least if you plan to run the 26" Hoosier QTP which is 9.5" wide).
Old May 13, 2013 | 08:37 AM
PATRICK B.'s Avatar
Thanks!
I run D2 c/o's
Just to be clear........ the pic above i posted was with the 24.5" M&H slicks but here is a quick pic with the 26" ET Drags on:
If you're interested please pm me
lancerman360
91
Apr 22, 2016 03:01 PM
Tykocoo
Jan 5, 2016 10:26 AM
.Adam
19
Sep 26, 2013 11:18 AM
antman_21
May 30, 2012 11:57 AM
DSMEVO15
13
Aug 11, 2007 09:04 PM
