15 and 16" wheel options with small front brakes?
Old Dec 14, 2011 | 04:41 PM
TurboTravis's Avatar
Hey guys,
What exactly is out there for 15 and 16 inch wheels that fit small front brakes and without a spacer (no spacer on the rear either)?
Thanks,
Travis
Old Dec 14, 2011 | 07:57 PM
Chu's Mom's Avatar
I'm looking for a set of 15's that will clear the STM small brake kit.
Old Dec 14, 2011 | 11:10 PM
Same here
Old Dec 15, 2011 | 05:08 AM
EmeryatSTM's Avatar
We stock the wheels and tires that we suggest but they will need a spacer in the front to work. I will try to get the setup on our site shortly.
-Em
Old Dec 15, 2011 | 08:04 AM
Chu's Mom's Avatar
I'm assuming these will be rota slipstreams with M&H slicks?
Old Dec 15, 2011 | 08:40 AM
EmeryatSTM's Avatar
Yes, And all of our slicks actually match. Every tire will have the same roll out.
-Em
Old Dec 15, 2011 | 08:55 AM
-Em
What's the weight/price of the spacer? I'm still interested with a spacer, just prefer without if possible.
Old Dec 15, 2011 | 10:24 AM
EmeryatSTM's Avatar
the spacers are pretty light but you will need to run an extended stud to use it. We use the ARP studs. I am not 100% sure what the weight is as I do not have them here at this time.
-Em
Old Dec 15, 2011 | 12:15 PM
-Em
Thanks man-I called Brian earlier to check up on a recent order and chatted with him a bit. Like you guys, it's my off season so I'm in no rush, but I'll continue to research this over the winter.
Old Dec 15, 2011 | 09:00 PM
StreetThisEvo's Avatar
15 x 7 Rota Slipstream +40mm offset are 13.2 lbs each and are pretty cheap and look good IMO. But like EM said do require a spacer and studs. I use ARP studs in the front and 10mm longer extended studs in the back. Spacers are about 1-2 lbs each depending on what type and size you use.
DN419
Apr 13, 2017 03:54 AM
lancerman360
91
Apr 22, 2016 03:01 PM
Mellon Racing
Evo 'For Sale' Suspension / Brakes / Handling
Jun 27, 2011 07:02 AM
Darkn3s
Jul 11, 2010 08:56 AM
stokEd
12
Mar 15, 2010 10:31 AM
