QM 8-leg; Street or Race version?
I can't decide what clutch I want to run. They have the street version which is rated for 600ft/lbs of TQ, and the race version that can hold up to 900ft/lb.
I don't think I'll be going past 600tq, maybe 550 at most, but I'd like to run the race just because the price is the same. The car will see around 5k miles on the street, and probably 10 track visits (over 50-70 launches) next season.
Is the RACE a lot more harsh for street driving? Is it harder on the engine? Would like to run it if its not that bad. Which one do you have in yours?? Input?
Thanks!
Thanks!
Currently using the street flywheel with the race disks. The car has seen about 5k miles so far and probably close to 100 launches. So far I am happy with this clutch and once you get used to it, it becomes quite driveable on the street.
My biggest question is just how much longer this clutch will last with the abuse I have been giving it.
Thanks for the info. How did you go about picking and choosing what parts you wanted? What pressure plate does it have? or are the PP's the same?
Still looking for more people with input
I have used both flywheels. The street is similar to a exedy twin but quicker engagement. Switching to the race flywheel I did notice a diffrance in driveability. It is more difficult to drive due to the lighter flywheel but there are some sacrifices you need to make in oder to go fast, im sure you know that
Pressure plates are the same. I would go with the race due to the lighter flywheel. Sure it might make street driving no so pleasant, but you get the hang of it rather fast.
Used the race setup, with a fresh shep trans. Clutch was great, never gave me a single issue. Couldn't make it slip if I tred. It quickly destroyed my transmission, eventually locking 4th out completely after maybe 1k miles. The disks are unsprung, which I believe is the main reason for my issue.
I recommend the Race version Scott. Especially for Drag racing and the amount of lauches you want to do. It will take you a little bit of time to get used to the QM race coming from an Exedy but its not that bad on the street at all. I drove the race version all last season on the QM and this season a couple times on the street. It just takes a few times getting used to. Thats my 02 bud
How many miles do you have now of the QM race version? I had 49k miles @540whp/478tq on my Exedy twin HD before I got rid of it. I DD the car and race almost every weekend on the street and every other month at the track. I have triple carbon now and I hate it cause it's not good for dd. It slips then grab then slips then grab lol. I was looking on this QM 8leg race version too or just get the exedy triple cerametallic cause some people say QMwont last for DD!?
I keep getting mixed responses on what is even different between the two 8-leg versions? I have heard its the flywheels, I have heard its the clutch disc, pressure plate......who has the real answer?
Why are people saying they have the street flywheel with race disks when the only difference between the street clutch and race clutch is the flywheel.
Are there street disks and race disks too?
