Changes for 2013
Got a few things done today to remove weight, first was the Brakeman rear brake setup. These saved 21lbs vs the stock rear brakes.
Then I swapped out my modified factory rear mustache bar for one made by Vassil, shaved off 6lbs here.
Weighed it today with everything assembled, current race weight with me in it is down to 2728 with all the fluids and me in it. Still lots of places to drop a lot of weight too.
Beautiful work and I am very jealous of that dry sump system. Do you still run an alternator on the car ? Reason i ask is if its in the rear of the engine then thats where the scavange pump goes... unless you have something fancy like the alternator driven off the rear diff or a 16v system
E-SPEC INDUSTRIES
Jan 11, 2013 08:01 PM
E-Spec@Tach Motor Works
Evo X Dyno Results
509
Nov 21, 2011 11:44 AM
teribble
May 17, 2011 09:55 AM
teribble
11
Mar 2, 2011 01:59 PM
Evo X Dyno Results
23
Feb 9, 2011 05:16 AM
