Changes for 2013
Old Jan 18, 2013 | 03:53 PM
johntsi's Avatar
Changes for 2013
Well after one of what had to be the hardest years of trying to make the car work I decided it was time to change what I know was causing issues and upgrade a few other things.
Plans for the car over the next few months are....
Remove some weight, the 2840lb race weight is making it hard on drivetrain parts so we will make it lighter but able to put weight back when needed for classes that require it where I want it. We are gonna switch to some carbon parts, removed the old cage and put a chromolly cage in its place and that will cert, and tube some of the parts of the car that will save weight. Because of the classes I hope to compete in it can never be tin canned as it has to retain most of the interior plus I just could never do it.
Next with the new pressure plate in the car to hold the power it has made it nearly unlauchable with the first gear in the dog box. Clutch is coming out and switching to a much heavier custom exedy tripple disc from Magnus.
Part of the tubing includes the front end so with all the added space I will be also switching to a FFM. And the turbo will be going to Forced to have the compressor upgraded to their billet one.
Will likely also switch to 26" tires this year as well to try to take more of the hit to the sidewall and help with traction. Lots of other small changes to the car and hope to have the drysump motor finished up and possibly swapped in later in the year. I will try to keep this thread upgraded as it progresses.
And so it begins....
a month later
Next is cut the inlet for the turbo in the front end.
Old Jan 19, 2013 | 10:11 AM
itsmrrizz2you's Avatar
thats 1 bad dsm
Old Jan 21, 2013 | 12:28 PM
Dallas J's Avatar
Veteran: Army
Turbo straight into the intercooler is bad a$$!
Old Jan 21, 2013 | 01:54 PM
NODAKevo's Avatar
This is looking really great. Have you set yourself any goals for 2013?
Old Jan 21, 2013 | 07:41 PM
johntsi's Avatar
Well last year was a hard teething process. Car trapped as high as 168, ran into lots of issues, coasted to 9.2@148 on a soft 1.78 60'. This year the goal is to get it down the track clean and reliably. I am well aware of what it should run, it working out the bugs to make it do it and do it consistently is what I am interested in.
Old Jan 22, 2013 | 06:35 AM
NODAKevo's Avatar
That is super impressive man, wish you the best of luck this coming season and hopefully the car will cooperate the whole year for you. 8 second time slips are sure to come.
Old Jan 24, 2013 | 05:12 AM
macspeed702's Avatar
looking really mean, time for the hole in the front bumper.
Old Jan 25, 2013 | 08:04 AM
Andrew@AMS's Avatar
Caught a few of these pics on FB. Car looks great John and is coming together very quickly. Can't wait to see it at Shootout again this year!
Old Jan 27, 2013 | 01:07 PM
MRfabolous's Avatar
very impressive man for sure 168 is flying
Old Jan 27, 2013 | 01:22 PM
Gordian79's Avatar
Looks good but those square tubes holding intercooler would bother me.But then again im picky with the details.
Old Jan 27, 2013 | 04:00 PM
ctfpevoVIII's Avatar
Thats one awesome looking setup. What do you think the cars going to run et @mph?
Old Jan 29, 2013 | 07:58 PM
ww04's Avatar
Is that a notch on weld magnums hiding in the garage?
Old Jan 30, 2013 | 06:14 AM
johntsi's Avatar
Car has already trapped 168 with issues. We will see what it does this year.
Yeah the mustang is in the process of having a turbo kit fabbed, billet Precision 76mm
Old Jan 30, 2013 | 06:17 AM
johntsi's Avatar
Started the car last night. Still have a lot of finishing stuff to do, shortening the dumps and exhaust, the finisher plates for the bumper. Some modifications of the IC pipe. We will dyno it first make sure it all works then do all the finish work and rehang the front end. After we make sure it all works together it will be blown ack apart one more time for paint.
Old Jan 30, 2013 | 03:06 PM
Looking good man . Good Luck with your runs.
