First time at the track with the Evo VIII
Old May 20, 2013 | 09:06 AM
matteclipse's Avatar
Not very good, high trap speed and high et.'s my best was a 12.94 at 111 mph
Old May 20, 2013 | 09:10 AM
boost556's Avatar
ok from your traps the car should go low 12's.just for comparison i ran 12.4 @110 and 12.5 @111 mph.Both passes was 1.7 to 1.6 60ft, i am sure your 60ft was bad that resulted in this.post up your time slip so we can see more details.Oh also i am making 355whp and 349 tq just to let you know as well.
Old May 20, 2013 | 09:18 AM
Evosick2332's Avatar
With that trap speed, your car should see low 12s. What was your 60ft? My EVO 9 has 3 bolt ons and I went 12.11@111mph.
-Full Turbo back exhaust
-AMS Lower intercooler pipe
-JMF 3" Intake
I got the car tuned from Devin @ Boostin Performance on virtual dyno the car made 338WHP/323TQ on 23 PSI on 93 octane. My ACD pump is bad and last week got a new one. When I went to the track it was 50 degrees with a 20mph headwind. I plan to go back in a couple weeks with the same mods and I think the car can go 11s.
Just wanted to share my results for comparison to yours. I think your car can see bottom 12s What's your mod list?
Old May 20, 2013 | 09:24 AM
There was an Evo 8 that ran a 12.05 and trapped at 116, so I was disappointed, my 60 ft for that run was 1.83, on another run I even trapped higher at 112.19, I will post the slips after work
Old May 21, 2013 | 02:58 PM
timeslips
23/matteclipse/null-2.jpg[/IMG]
Old May 21, 2013 | 02:59 PM
Old May 21, 2013 | 03:19 PM
boost556's Avatar
work on your launch and you should be in the 12's consistently.How much power are u making also what tire pressure were u running?
Old May 21, 2013 | 03:27 PM
Idk how much power, the tire pressure was 41 psi, and I had 18" wheels on not the stockers, im putting those on next time.
Old May 21, 2013 | 10:33 PM
boost556's Avatar
yeah too much air, next time start at 32 psi and drop according to track conditions.
Old May 22, 2013 | 02:20 AM
I will definetly try that
Old May 22, 2013 | 04:42 AM
lostsoulsevo's Avatar
dont be surprise if you have to drop your stockers to 22-25psi. i had to as well, work on your shifts to.
Old May 22, 2013 | 05:56 AM
I will try that too, my stocker have crappy winter tires on them, so its no problem burning them off
Old May 22, 2013 | 01:41 PM
I would bring those street tires down to 20PSI. 41PSI is WAY up there, but still came out pretty good for that much air in the tires. Work on your shifting a little bit, and your car will be a consistent 12 second car!
Old May 22, 2013 | 02:41 PM
Thanks for all the good info!
Old Jun 3, 2013 | 02:24 PM
egis's Avatar
don't feel bad bro.i run E85 on stock 8 turbo and basic bolt ons.yesterday i felt like a clown at the strip because my best was 12.5-12.3 @112 mph my 60' was like 1.7
