First time at track with Evo. 1st pass 12.5 @ 110
Old Jul 8, 2013 | 10:45 AM
DaRw1n's Avatar
So a week or so ago I took my 9 SE to the track for my first pass in it ever.
Two step is at 5900. Makes about 7psi off the line.
Mods: Works TBE, ETS FMIC, Exedy Twin HD, 21psi (Grimmspeed).
Thoughts? What should be my next mod?
Old Jul 8, 2013 | 10:49 AM
escodotcarter's Avatar
nice pass, next mod should be e85 !!!
Old Jul 8, 2013 | 10:51 AM
DDATuned's Avatar
Old Jul 8, 2013 | 11:14 AM
DaRw1n's Avatar
Ive tossed around the idea. Id need injectors most likely. That's about a $600 purchase for some decent 1000's.
I was thinking cams and a retune.
Originally Posted by Remy
Old Jul 8, 2013 | 11:20 AM
nadevo's Avatar
Licp
Old Jul 8, 2013 | 11:23 AM
Evosick2332's Avatar
Next I would do a LICP, some injectors, fuel pump and E85. That will really wake the car up. Congrats and that's pretty good times for your first time out
Old Jul 8, 2013 | 12:05 PM
06MREvo's Avatar
Instead of throwing more mods at it to go faster I would go to the track again & work on your 60 ft. Get the 60 ft down to 1.6Xs & you will have some low 12 sec passes, easy...
Old Jul 8, 2013 | 12:11 PM
evo8426's Avatar
PTE 1200 are $300 and FIC 1100 are about $450. I would skip the cams and do either set of the injectors I mentioned.
Old Jul 18, 2013 | 06:05 AM
egis's Avatar
Licp ,injectors,25psi wg actuator and E85 if it's available near you bro
Old Jul 18, 2013 | 06:13 AM
Raptord's Avatar
This this this. Get yourself faster before making the car faster.
Old Jul 24, 2013 | 08:42 PM
Abacus's Avatar
Thats a pretty good time for your mods. Drag racing really wears on the Tcase. You only get so many launches before the clutch or something gives. At a 1000 either way it doesn't seem worth it for 12 seconds of fun.
What about going to an auto cross or road course and using the car for its intended purpose. Its a much better fun/time per dollar ratio IMO.
If you want to stick with drag racing I would get a W/G actuator,1300CC injectors and run E85. You should be able to make close to 400/400 with some tuning.
EvoVenomIX
Jan 2, 2014 08:37 PM
GotWheelHop
Mar 15, 2013 12:29 PM
dwayne624
Aug 25, 2008 06:40 PM
BCOZEVO
Jan 24, 2008 10:18 PM
