First time at the track....
Old Aug 19, 2013 | 05:19 AM
Xplosiv's Avatar
Took the evo out to the local track friday night for the first time. This was my second time launching this car and the first trip ever to the track in an AWD car. DA was 2100-2300 all night with a nasty 90-100% humidity. So im hoping to see some better numbers with better air and a little more seat time.
1st Run: 12.49@115.22 2.0 60' (Rolling out from 2800rpm)
2nd Run: 12.20@111.20 ?.? 60' (right lane 60 timers were fubar, launching off the 5500rpm 2step, tried to shift into 5th instead of running out 4th)
3rd Run: 12.38@115.68 1.9 60' (launching off the 2step and spinning)
Old Aug 19, 2013 | 05:45 AM
High_PSI's Avatar
Quality runs, right where you need to be with the stock turbo. You can get deeper into the 11's with more mods of course but basically 11.7 on Pump is attainable.
Old Aug 19, 2013 | 05:58 AM
Xplosiv's Avatar
I'm on E85
Old Aug 19, 2013 | 08:57 AM
boost556's Avatar
good times that's what i run with 355whp, i just went back with a little more mods that put me to 403whp but i blew up before the quarter mile and run 12.9 @90 mph.How much power you making?
Old Aug 19, 2013 | 10:15 AM
Xplosiv's Avatar
Under the previous owner it dynoed 392/421 on evo dynamics mustang dyno
Old Aug 19, 2013 | 12:44 PM
4g63evoeight's Avatar
Set the 2 step to 6k, slip the clutch a little quicker and shift the car faster.. With that mph you could run like an 11.5-11.7 no problem
Old Aug 19, 2013 | 06:23 PM
High_PSI's Avatar
Originally Posted by Xplosiv
I'm on E85
Should be much higher traps on E85, those are Stock Turbo Evo VIII times even with the 9.8 hot side (I ran those times myself with BPU only).
E85 should net you into the 118MPH range it's 105 octane plus much colder. Up the boost maybe?
Old Aug 20, 2013 | 08:13 AM
Xplosiv's Avatar
Im already at 28 psi. Anything else that could be causing the issue? Also that same night a buddy went with me and he has basically the same car with the exception of his isn't an SE and has a sunroof. With his 2step at 6k he went 12.008 @ 115.XX. Im assuming the DA and humidity might have had something to do with the low traps?
Old Aug 20, 2013 | 08:44 AM
Danner's Avatar
392 should be high teens. Boost Leak?
Old Aug 20, 2013 | 10:14 AM
egis's Avatar
Im not an expert but if u can make 60' like 1.7 it would help you a lot.
Old Aug 20, 2013 | 10:18 AM
egis's Avatar
Oh and do you nlts and how much boost you holding in 4th?
Old Aug 20, 2013 | 10:26 AM
Xplosiv's Avatar
Yeah, I have a feeling a stickier tire would help tremendously. Im currently on michelin pilot sport all seasons in a 235/45/17.
Old Aug 20, 2013 | 10:28 AM
Xplosiv's Avatar
I dont NLS, and wont be until I get my trans built. Im just not comfortable doing it on my stock synchros. As far as holding boost I wasnt really paying attention to it, I believe after 5k it tapers off to about 22psi.
Old Aug 20, 2013 | 12:25 PM
egis's Avatar
Everything sounds good then.improve your 60' a bit and you good with set up u have
Old Aug 20, 2013 | 06:32 PM
High_PSI's Avatar
you need a 1.6 60 foot. Remember the better the ET generally the lower the trap. Lower yout 60 foot to 1.6 and youll be in the 11's.
