New Best!!
Old Apr 2, 2004 | 08:04 PM
  #31
bo0oost's Avatar
TURBODAWG - How much boost were you running?
Old Apr 3, 2004 | 07:20 AM
  #32
TURBODAWG's Avatar
I was running about 65% duty cycle on the Profec B Spec 2. That would spike up to ~23 psi and drop down to ~ 21.5 psi on the top end. I think the stock turbo maybe close to running out of air, especially since it is having to blow thru the stock intercooler and all stock intercooler piping.
Brian
Old Sep 26, 2004 | 10:33 PM
  #33
bo0oost's Avatar
Sorry to bring this thread from the dead, but what intake were you running at the time?
Old Sep 27, 2004 | 08:10 AM
  #34
TURBODAWG's Avatar
I was running the HKS super mega flow intake. This is the $105 intake, it is just the filter, and an adapter. It does not come with the hard pipe from the MAF to the turbo, like the Racing suction kit does.
Brian
Old Sep 27, 2004 | 08:36 AM
  #35
Rez90's Avatar
Have you ever dyno'd your car...cause 118+ through the traps is very fast
Old Sep 27, 2004 | 08:06 PM
  #36
TURBODAWG's Avatar
I haven't dynoed the car yet. I would like to know how much power it would make on a dynojet. I may be able to get to one in the next couple of months. I have added a FMIC and switched from the B&B catback to a Greddy Titanium catback. I hope that I would have picked up a little power with those 2 new mods. I haven't been back to the track since those 2 additional mods. My car was at full weight minus the spare tire during that run.
Brian
Old Sep 27, 2004 | 09:07 PM
  #37
KIDBANGA10's Avatar
Brian
How much boost were you running and what was your airfuel ratio? Also what kind of boost controller were you using?
Old Sep 28, 2004 | 09:08 AM
  #38
bo0oost's Avatar
From the buttdyno, did the switch from the B&B to the GReddy feel better? Felt like a lose of torque?
Old Sep 28, 2004 | 01:35 PM
  #39
Geo@EvoStore's Avatar
Have you gone to the track recently? Have you been able to come close to the 118mph in the hotter weather?
Old Sep 28, 2004 | 02:21 PM
  #40
VTECH8TR's Avatar
Originally Posted by ZeroFrost
dude for 12.241 with those mods..... you should be in the high 11's bro. I ran a 12.99 on my stock EVO with absolutly no speed mods. All i had was a BOV that VTA.
Originally Posted by Sano
you must either be the best driver here or you have a strong car, I am leaning towards the latter. I agree with trbo dad. mouthing people = those times are very respectable.
LMAO...
Old Oct 4, 2004 | 08:20 PM
  #41
TURBODAWG's Avatar
I was running 23 psi peak, with a sustained boost of around 21 psi. I was using and still am using a Greddy Profec B spec 2. I didn't have a wideband hooked up at the time, I was tuning with Pocketlogger. I kept leaning it out on the 110 octane fuel until I got .88 to .90 on the O2 voltage. I also monitored the timing to make sure that I wasn't knocking. The timing stayed good. I now have a wideband, and would estimate that I was running ~12.5 to 12.2 air fuel ratio.
Brian
Old Oct 4, 2004 | 08:25 PM
  #42
TURBODAWG's Avatar
I couldn't really give you a good answer to this. I switched to the Greddy Titanium and hooked it up with the stock downpipe and stock cat. I had a problem hooking the new exhaust up to the UR testpipe and Helix DP that I had. I sold the DP and UR testpipe and got a new SP/Helix downpipe and a RT high flow cat. The new SP/Helix Downpipe and RT cat fit well with the Greddy exhaust. So I can't give you a direct swap comparison. I don't see why you would lose anything at all when going from the B&B to the Greddy Ti, except for about 20 lbs.
Brian
Old Oct 4, 2004 | 08:30 PM
  #43
boomn29's Avatar
Ran a new best last night at Rockingham dragway. The track was pretty slick at times. It would hook for a few runs then be super slick.
Stock injectors, Stock intercooler, Stock IC piping.
60' 1.859
330' 5.218
1/8 7.954
MPH 89.22
1000 10.297
1/4 12.241
MPH 118.44
MODs are:
Helix 3" downpipe
UR 3" testpipe
B&B Catback
HKS Super AFR
Dynoflash Mail in
Walbro 255
HKS 264 Cams
HKS GDmax twin plate clutch
B&M short shifter
Nice time for those mods. Good to see low times with 264's!
Old Oct 4, 2004 | 08:31 PM
  #44
TURBODAWG's Avatar
I haven't been to the track since the early spring. I hope to get back to the track soon. The car feels a good bit faster and smoother since I installed the Greddy FMIC and the Greddy Ti exhaust, even with the RT cat in place instead of the UR test pipe. I think 118 mph runs shouldn't be a problem even in the heat, unless it is 90+ degrees. The other runs were made with the stock FMIC and cool weather. I think with the Greddy FMIC and slightly warmer weather, I shouldn't be too far under power compared to the cooler nights back in March.
Brian
Old Oct 4, 2004 | 08:33 PM
  #45
TURBODAWG's Avatar
Thanks. The 264's are the perfect combination for a stock turbo, stock ecu car. IMO.
Brian
