Som 2.4l + fp 6466tz
Old Jul 27, 2015 | 06:26 PM
AreSTG's Avatar
SOM 2.4L + FP 6466tz
The long wait for my trans to get back from TMZ was over. Spec-Ops Motorsports put the trans in, I redid the fuel system, and Friday night it hit the rollers with a new larger hotside on the FP 6466TZ. The larger hotside made the same numbers on the dyno, but on a conservative tune with lower boost, than it was making on higher boost and closer to kill mode tune. Left it there and hit the track an hour later.
Drove to the track, swapped the tires, and first run ran a new PB of 9.8. SCORE! Ended the night with two more PBs, both 9.7's.
Next day, Saturday, we decided to go to Rockingham for test and tune, an hour away. SOM loaded my car in the trailer, and we went down in their RV. Based on the day before, I wanted more power out of the hole. Matt pushed some buttons and I was making double the boost at the line. Sadly, prep was not quite as good. The good news, I no longer needed to ride the clutch to stay in power. After a shakedown pass on the new 2-step, I ran another PB of 9.6 @ 152mph. Adjusted the chassis/tires and ran a 9.5 @ 149mph. The car kept getting faster every pass for 2 days. At last call for TNT, we finally decided to up the power since the car felt setup and solid. Felt like it was on the way to a high 9.3 and the clutch let go in middle of 4th gear with the added power, coasted to 9.8 @126mph.
Huge thanks to SOM, as always. For the great service, great performance, a 3 year old 2.4L that's doing things no 2.4 should, and of course the friendship. Also, a thank you to Forced Performance for their great products, and my new transmission builder who will get ALL future transmission work, Tim Zimmer at TMZ. I've used all the big names, and he is top notch both personally and professionally.
Can't wait to turn the wick up, and not to mention throw the Magnus intake manifold on the car in the future. For those who know my car, it is still the tagged/insured street car it has always been, not even an O2 dump
Old Aug 3, 2015 | 08:10 PM
thestig0711's Avatar
Atta boy. That thing is scootin.
Old Aug 4, 2015 | 06:29 PM
WikdEvo's Avatar
car is hauling! is the head or block o ringed? which hg are you using?
Old Aug 6, 2015 | 07:29 AM
AreSTG's Avatar
I think it's a cossie HG, but don't quote me. Buschur head is o-ringed, 4th year going now
Old Aug 12, 2015 | 03:43 AM
Liqquid's Avatar
Fantasic! Which hotside did you switch to if you don't mind me asking
Old Aug 12, 2015 | 04:54 PM
Spec-OpsMotorsports's Avatar
Its running a cosworth 87 MM HG. He switched to the Tial 1.03 ar hot side.
-Matt
Old Aug 13, 2015 | 07:08 AM
WikdEvo's Avatar
Very impressed with this car. What final drive and 4th gear do you use? What rpm do you see going through the traps?
Old Aug 13, 2015 | 04:36 PM
AreSTG's Avatar
4.11 fd, oem 4th gear.
Not sure on rpm, believe there's a good bit left. Something wrong with the car giving me a violent shake in 4th gear that we have to figure out.
When I'm able to stay in it through 4th gear, I'll let you know what the logs say and what mph it traps.
Old Aug 14, 2015 | 12:28 AM
car_nut15's Avatar
What clutch are you using??
Old Aug 14, 2015 | 04:22 AM
AreSTG's Avatar
Currently the QM twin
Old Aug 14, 2015 | 04:30 AM
car_nut15's Avatar
Street or race?
Old Aug 14, 2015 | 05:01 AM
AreSTG's Avatar
Didn't know there were two, but I'm positive it'd be the race version
Old Aug 15, 2015 | 10:52 AM
Liqquid's Avatar
-Matt
Thanks! Did you guys do a dyno post? Super interested in the change from .82 to 1.03!
Old Aug 15, 2015 | 12:54 PM
AreSTG's Avatar
.82
Old Aug 15, 2015 | 12:56 PM
AreSTG's Avatar
Sorry, on mobile...
That was .82 tial, stock ported intake manifold, C16 fuel.
I found that on Facebook. I don't have a graph from this year on me.
