First Time at the track on my EVO
Old Jun 27, 2004 | 10:08 AM
Speedlimit's Avatar
Admin Emeritus
Originally Posted by Audi2ptzero
Odd you say that about the stock clutch. Smogrunner does not have any issues with the stock clutch while putting down 12.2's at 113 mph on a stage 1+ setup. Even on my first day at the track with his car it held 5500 rpm clutch drops pulling 12.3-12.4 at 110-111 mph in a head wind. I think the stock clutch seems to last longer dropping it then slipping it.
Hi,
Good points but I think you missed mine. Smoggrunner's experience with a stock clutch is the exception rather than the rule. Since every car and clutch is different, the comparison is of little value. GOKOU's stock clutch is slipping now and once he gets the BR stage 4 custom tuned, ups the boost with race gas, he will probably toast what is remaining of the clutch. Whether he dumps it or slips it.
If he upgrades to an "on/off" aftermarket clutch, the chances of breaking the drivetrain improve substantially with a sticky track and high RPM dumps. Most high HP racers I know (with manual transmissions) "feather" the clutch. However, each should use the technique they find works best for them. Your individual experience (Smoggrunner's car) seem to be contrary to the majority of owners. I assume driver skill and as Napolean understood the fortunes of war..... "Don't Give Me Good Generals, Give Me Lucky Generals". (paraphrased). Have fun!
Speedlimit..
Old Jun 27, 2004 | 10:10 AM
3000ways's Avatar
Originally Posted by Simpply
and you all are still slower than S4s ! smoked another Vishnu tuned Evo tonite
I was going to go off topic also, but decided forget about it, great times for the EVO. Believe what you want Simpply stupid.
Old Jun 27, 2004 | 11:30 AM
GOKOU's Avatar
Audi2ptzero:
Clutches on all cars are different. Some clutches on these cars slip even on stock or midly mod cars. All I can tell you is that mines was smelling and slipping. If I had 2 more runs the time could be better but I didn't want to take the risk of destroying the stock clutch.
IF you run 12.3-12.4 on full interior, pump gas, 20psi, stock clutch then I give you props
Simpply:
This is not a road racing post. You car may be fast but there are always faster cars out there. It's how you react to a win or lost that signifies you from a newbie or a competitor. You clearly shown which group you belong to. If your car runs 12 with full interior and on pump gas (street setup) then I give you props no matter what car you drive. There are no timeouts on the street to start changing setups.
watchout:
Weather that day was great. 80 degree weather, sunny, cool with little humidity.
Old Jun 27, 2004 | 11:38 AM
Grod101's Avatar
Great time.... forget about the slow *** hater
BS....... show some proof..... I want vids or timeslips of your s4...
Old Jun 27, 2004 | 12:04 PM
Speedlimit's Avatar
Admin Emeritus
Please keep this thread on topic. Simpply got the desired effect he was shooting for which was arguments. He will not be responding your comments as he is banned from this thread, so ...... lets talk about GOKOU's original post. Thanks.
Speedlimit....
Old Jun 27, 2004 | 12:42 PM
Audi2ptzero's Avatar
Sure not faster then S4's running "hybrid K04's" running 2.2 bar of boost on race fuel. I am sure I will put most other S4's to shame. I have raced standard K04 kit 2.7's and they were no were near a match to even smog's car which at this point has less top end power then my car which put down 114 mph even off the throttle at carlsbad.
You should have showed up at carlsbad mike, you would have lost all your money to plenty of "street driven" civics and the evo8 running there yesterday.
Old Jun 27, 2004 | 12:59 PM
Originally Posted by watchout
Um how much money do you have invested in that thing? What mods do you have? I believe the thread is relating to a guys first time at the track, not what cars you can beat in a race. He is looking for advice I am sure he doesn't care about your S4.
Shane
I would say he has much more invested in his S4 then everyone on the board combined has in their Stage 1+'s. Also add in all the drive line parts he has shattered at the tracks and all the K04 hybrid turbos he keeps blowing up.
Hey simpply, LOOKED in a K04 parts bin "lately"?
Old Jun 27, 2004 | 02:17 PM
metaphysical's Avatar
Registered User
Switch to an AEM EMS with MAP conversion. You will awaken your Stage 4 monster.
Old Jun 27, 2004 | 06:53 PM
Novtec1's Avatar
Veteran: Army
excellent times man and damn good 60' and on 93 guess its time to replace that stock clutch.... again good job!!!!
Old Jun 28, 2004 | 08:46 AM
Noize's Avatar
EvoM Administrator
Good job, especially considering the heat and humidity as of late.
Old Jun 28, 2004 | 08:58 PM
Nad1370's Avatar
Originally Posted by GOKOU
First time at the track and got 2 runs. BR4 setup with 272/272 cams and turbo RFL BOV. Jack and spare tire in the car. MBC set at 20psi. 93 octane gas. dynoflash. Stock clutch which was slipping and was smelling. Time to get Exedy Twin Disc.
Any recommendation for better times. I was hoping for lower times. I thought I saw posts where the times was better then 12.5 but with stage 1 or 2 only. Not sure if they use race gas or not. Should I be disappointed??
Run 1 - 4500 rpm slip the clutch
60 - 1.824
330 - 5.225
1/8 - 8.062
mph - 85.38
1000' - 10.519
1/4 - 12.581
mph - 107.87
Run 2 - 5000 rpm slip the clutch
60 - 1.773
330 - 5.286
1/8 - 8.095
mph - 86.71
1000' - 10.510
1/4 - 12.530
mph - 111.96
Great run GOKOU!! excelent times for pump gas and 0nly 20psi. you shouldn't be disappointed with those runs . only thing I would be frowning on is your slipping clutch . If your getting the " twins" you won't be able to slip the clutch. might be more stress on your drivetrain.
I myself am trying to get low 12's @ 113-114 on pump gas ( 93oct ) but with a H/F cat.
Old Jun 29, 2004 | 02:00 AM
I guess your lucky you dont have to try for that in socal. Hard enough to get those times on race chips and race fuel at 25psi. But then most of the pump gas evo's still run 13's here.
Old Jun 29, 2004 | 09:08 AM
Fourdoor's Avatar
Hey Nad1370, you and I have the same goal! After finding out that I lost only 10 HP on the dyno dynamics AWD dyno at AXIS racing when I swaped in my high flow cat I decided to leave it on and see what times I can run with it in place. I love how quiet my BR exhaust is with the cat in place and the Magneflow muffler option
Keith
