Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
ralliart techniques?
Old Jul 24, 2005 | 07:28 AM
Ralliart_on_LSD's Avatar
hey i got a somewhat nicely moded ralliart, but unfortanatly on stock tires... when i launch i rev to 3500-4000 rpms and feather it out just perfectly so that i get small wheelspin, and i do not smell my clutch burning at all.. works very good for me.. im just wondering what you guys do w/ an equally modded ralliart, and what are your shifting points... i usually redline (6800 ish) at first and 2nd, then 6200ish the rest...(mivec looses alot of power after 6200...
one more thing... i red a post on here from early december about a guy who kept grinding 2nd gear alot even tho he held the clutch in and did everything right, and i got the same problem... i grind it up SOMETIMES, but not all the time... any advice how to help me with that?? (yea yea i know, learn to drive stick better) but for real, any advice would help me
so to re-cap, i have 3 questions..
1. where do you guys shift at?
2. what rpms do u guys launch at?
3. any advice on how to not grind 2nd?
Mods include - CAI, exhaust, RRM piggyback, clutch, flywheel, clutchline, short shifter, motor mounts, and CF hood.
i would like advice from Ralliart drivers with close to the same mods i have, but any advice would help... thanks alot guys
Old Jul 24, 2005 | 10:08 AM
blk-majik's Avatar
i launch and shift about the exact way you do. my experience has been about the same. if you can manage a good launch at launch at those rpm ranges /w ur mods, u know what ur doing =) what kinda times are u putting down? I usually get about 15.3's these days. i dont have the flywheel or clutch or weight reductions, but otherwise we are the same.
our car does like to lock us outa 2nd. My best method was to not think about it and try not to force it. It also helps to let off the gas about 20% between teh 1-2 shift, but that really hurts the ET and I say if ur gonna go for it, go all out....but it helps get a concistant 2nd.
may wana try some redline transmition fluid, as its a bith thicker and more slick and might help get a better engagement. otherwise, practice practice practice =)
Old Jul 25, 2005 | 03:57 PM
alright man thanks for the help, and by the way, i love your icon, megaman is the man, lol
i dont have any times yet, i didnt take it to the track yet, and i probly wont until i get my rims and toyo's put on (maybe 2-3weeks?) but when i do, i'll have dynos, time slips, and alot of bragging, lol
again, thanks for your help, and thanksfor the complement (telling me i know what im doing) lol.... just one quick question... u say u launch he same as me... whats your 60'ft time???... thanks
Old Jul 27, 2005 | 07:32 AM
blk-majik's Avatar
I can get 2.2 60's on stock rims/tires. I need to work on some improvement there, as I know the car can do a 2.0 with the right conditions. But I do suggest you get to the track any time u can and as much as u can =) Seeing ur times the entire way down the strip really helped me focus on what needed work. Like, if I have a pretty good run /w a good 60', but a bad trap speed, I know I can do better and know I need to focus on my powershifting in the later gears. experience counts =)
Old Jul 31, 2005 | 04:59 PM
theace's Avatar
neat
Old Aug 1, 2005 | 09:24 PM
theace's Avatar
neat man sounds good...
Old Aug 15, 2005 | 10:21 AM
reimundo's Avatar
do you push your clutch all the way in? and do you power shift?
Old Aug 15, 2005 | 10:44 AM
blk-majik's Avatar
1) usually not while racing =)
2) sometimes, but it increases the chance of grinding (but helps ur ET if u nail it on every gear!) if ur going all or nothing (ie: not a test run) then powershift every gear just dont break it! and dont get into the red, or u will grind bad when u try to powershift. and do it FAST or ull get locked out every time
keep an eye on the engine dampanger thread. should help reduce grinding alot
Ralliart367
27
May 13, 2013 09:58 AM
ILuvJDM
10
Jun 14, 2012 04:04 PM
pb91
Jun 8, 2011 02:44 PM
Wht9er
14
Sep 16, 2009 06:20 PM
BluEVOIX
May 18, 2009 10:48 PM
