Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
brake boosting...?
Old Dec 4, 2005 | 08:45 AM
tougetuned's Avatar
brake boosting...?
i just recently heard the term BRAKE BOOSTING, and was wondering what exactly it is? i searched but did not find... i use LEFT FOOT BREAKING to keep the car balanced and the turbo spooling in turns/corners, and i am thinking that BRAKE BOOSTING is similar, that it is meant to get the turbo to spool faster or keep it spooling or something on straights like when LEFT FOOT BRAKING for turns/corners, but i am not totally sure. if anyone can help, thanx
Old Dec 4, 2005 | 08:49 AM
Greg K's Avatar
the brake booster reduces the pedal effort by using engine vacuum on one side of a diaphram to assist in pedal travel.
LFB will keep the turbo spooled up and give you more torque on corner exit.
the two are completely different...
Old Dec 4, 2005 | 10:43 AM
tougetuned's Avatar
cool, thanx for the info
Old Dec 5, 2005 | 04:34 PM
CRVdrftR05's Avatar
^.^; still need to practice LFB more.... ahhhh...i wanna go home!
Old Dec 5, 2005 | 08:35 PM
ez's Avatar
ez
I also hear a lot about people using this on the street to spool up before a ..... from a roll. As they pull side by side, the brake is used to hold speed, load the engine, and spool it up prior to go time...
Old Dec 5, 2005 | 08:43 PM
dEdiYT11's Avatar
This is what I do. It does help the spooling process for my 3037
Old Dec 5, 2005 | 08:49 PM
ThunderOZ's Avatar
yea ive heard that alot for turbo cars but i think its also a good way to wear down ur pads/rotors...
Old Dec 9, 2005 | 04:20 PM
05SilverEvoVIII's Avatar
Very Very helpful and effective
Old Dec 9, 2005 | 04:21 PM
never heard of this but sounds like it would be very effective as well going to try it out.
Old Dec 27, 2005 | 12:49 AM
Jakeg97's Avatar
1. go to the best gear for whatever mph you are gonna race from
2. while still on the gas gently press the brake pedal, you'll want to press it hard enough
that it starts slowing you down. But to keep from slowing down you apply more throttle.
3. The harder you ride your brakes the more load you put on your enigine. the more load you put on your engine the more boost you will build. (keep an eye on your gauge)
4. And as soon as you are ready to start go WOT and at the same time release the brakes, and that lovely sensation of boost is already there waiting for you rather than you waiting for it.
The key is to find just the right anount of preassure to apply on each pedal but that becomes very easy with a little pratice.
Old Dec 27, 2005 | 09:00 AM
sleet's Avatar
Yep, you'll take off pretty damn fast with 20PSI already spooled.
Old Dec 29, 2005 | 08:26 AM
rkm625's Avatar
going to work might be pretty fun today
Old Dec 22, 2006 | 07:24 PM
XK120's Avatar
<brings thread back to life> heard of this before and now I know how to do it..besides brakes, is this bad for your car?can't wait to try on the street
Old Dec 28, 2006 | 11:03 PM
-=SPECTRE=-'s Avatar
I've tried it a few times and with the stock 16G it doesn't really make much of a difference. The stock turbo already spools up pretty quick. If you have a big turbo though it has a much more noticeable effect.
Old Jan 5, 2007 | 09:36 AM
AlwaysinBoost's Avatar
brake boosting is hardest on your clutch disc, the brakes can take it.
