Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
How To Brake
Old Apr 6, 2003 | 08:25 AM
jfh's Avatar
jfh
Great post Claudius.
Additionally, in order to obtain the pedal feel necessary to modulate your braking pressure, the placement of both feet is critical. First, your left foot should be firmly braced on the dead pedal to prevent the forward transfer of your own body weight and subsequent unwanted increase of pedal pressure on your brake foot. (You obviously cannot leave your left foot on the dead pedal when engaging the clutch for downshifting. In those instances, a good harness or properly adjusted seatbelt will stabilize your body weight.)
Second, the heel of your brake foot should remain on the floor and pivot between accellerator and brake pedals. Lifting your foot off the floor when changing pedals is a gross muscle movement and prevents the smooth weight transfer described by Claudius as well as the fine pedal pressure adjustment required to achieve and maintain threshold braking levels.
Third, foot placement on the brake pedal should allow you to rapidly apply sufficient pressure through the ball of your foot and then make fine adjustments by increasing or decreasing pressure with just your big toe while maintaing the primary pedal pressure with the ball of your foot.
There are other braking techniques (heel/toe, trail braking, etc...)that deserve their own separate discussions.
Driving is about finesse and smooth transitions between braking, cornering, and accellerating. Through subtle exchanges between driver, chassis, and drivetrain you will develop the feeling of flowing through a circuit instead of attacking it. Smooth is fast.
