Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
what does dropping clutch to launch damage
Old Mar 22, 2008 | 11:31 AM
  #46
Arkitek's Avatar
thank god i never launched the evo even before i knew about the dumping thing. it was my common sense thoguh that help..there was no way i thought that dumping the clutch on a awd could be good on stock tranny and t-case..
Old Apr 2, 2008 | 11:05 AM
  #47
FX11's Avatar
yup, i launched on stock clutch, blew it, replaced with new aftermarket clutch and after just 2 hours of driving, i have to go back in and change transfer case. (soo much money $$$$$ it sucks!!!)
i was in a real **** hole, i was even thinking of selling the evo glad i didnt tho, and yes take advise, dont ever dump, if you HAVE TO launch, then learn how to let it slip then catch.
rebuilt used t-case is about 1700 alone, and if u dont know how to do it yourself, or dont have the tools, like me, it makes a huge hole in your pocket
labor = mad $$$$$
aftermarket clutch = 300-800 $$$
horrible feeling inside and missing ur evo =
Old Apr 3, 2008 | 12:42 AM
  #48
CalebL's Avatar
Holy crap, thanks now I don't even want to attempt learning to launch in my Evo. That is insane...Almost makes you want to save up for a shep/TRE T-case before even hitting the track.
Old Apr 3, 2008 | 05:42 PM
  #49
crazyitr's Avatar
My transfer case cracked after 1 launch with my new exedy twin disk. I guess my stock clutch was slipping more than I thought. Worst part is that when my tc case came out the input shaft to my tranny was broken, as well as the rest of the tranny. So I was out a tranny and transfer case all at the same time. $4k at TRE and I am almost back in business. Not to mention $2500 on the clutch install that saw very little use. So $6500 in drivetrain repairs/upgrades from drag racing.
Old Apr 17, 2008 | 01:11 PM
  #50
Mr. Evo IX's Avatar
All the broken tranny / transfer case combos are almost always the Exedy Twin.
What's interesting is that this clutch has a real smooth engagement so go figure. A buddy destroyed his "combo" with ~350whp.
If you get a Exedy Twin, dont dump it unless you want a Shep / TRE tcase and tranny.
Old Apr 20, 2008 | 03:04 PM
  #51
ej20_ftw's Avatar
wow just wow...
Old May 1, 2008 | 01:32 PM
  #52
meffiez28's Avatar
Registered User
Take these horror stories with a grain of salt, although do pay attention. Keep in mind these are mechanical parts. They can and will break. But also keep in mind how many cars don't have problems.
It really doesn't matter wether your drag racing, road coursing or autoxing. If you drive your card hard stuff will break. But not everyone will have catastrophic failures.
Doesn't matter if your in an Evo, and STi, or a Mustang, it's all relative.
Bottom line, if your going to play, be prepared to pay.
Old May 1, 2008 | 06:07 PM
  #53
wizzo 8's Avatar
True dat
Old Oct 5, 2008 | 02:30 AM
  #54
petersk2's Avatar
Real quick question guys, I understand that its not good to dump the clutch otherwise damage may occur, what about aggressive shifting, like on a 1-2 shift and feel the impact to the rear diff?
Mods: Buscher Lower IC pipe, EBC 22-23psi, Cobb Access Port, Cobb TBE w/hi-flo cat.
Old Oct 5, 2008 | 02:53 AM
  #55
APEX'iEvoIV's Avatar
All of the above is a no no in an EVO, easy on the launch, easy on the shifts. Altho in saying that, I also learned this the hard way, having replaced the clutch 4 times so far, the transfer once and a rebuild on the G'box.
Old Oct 5, 2008 | 10:13 AM
  #56
def1's Avatar
Why would u dump the clutch? I slip the clutch and still get wheel spin. No broken parts yet but im not pressing my luck. I rarely ever see the drag strip.
only launch when u have to
Old Oct 7, 2008 | 06:02 PM
  #57
wizzo 8's Avatar
I dont think slamming gears will break anything but wear the synchros out. If you get solid mount rear diff mounts you wont hear that thud from the rear on hard shifts.
Old Oct 8, 2008 | 01:21 PM
  #58
dek0026's Avatar
back on topic.
what doesn't launching hurt? probably the brakes
Old Oct 8, 2008 | 09:09 PM
  #59
meffiez28's Avatar
Registered User
Originally Posted by dek0026
back on topic.
Clutch, Tranny, drivetrain components.
Old Oct 9, 2008 | 12:24 AM
  #60
MATT@WORKS's Avatar
