Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Shifting an evo correctly. ????
Old May 12, 2008 | 05:32 AM
  #31
EvoDom's Avatar
Originally Posted by booster9
lol well actually its barley pushing in the clutch, barley letting go of the gas, and using your body to shif. (leaning into it and gridinging the gears intoeachother)
what??? nooo. double clutching is not that at all
double clutching is clutch in- put car in neutral- clutch in - put car in drive. its pushing the clutch in to get into neutral and pushing the clutch in to get outa neutral if u do it fast and are good at it, it is 100% smoother on the tranny.
not using ur body
Old May 12, 2008 | 05:59 AM
  #32
fame118's Avatar
that bump is cuz your dumping the clutch just come off the clutch easier. I had a honda also u can beat the **** out a honda but not the evo.
Old May 12, 2008 | 06:44 AM
  #33
Burklow's Avatar
Rear diff "smacking". If you ride with an Evo guy with a lot of miles under his belt, they'll shift fast without that sound. Watch drag racing videos on youtube or something. They're quick and "smooth" on the drivetrain.
When my Honda friend (FR...S2000) drove my car the first time, he did it too. Loud rear bang every hard shift. I told him to shift slower with more time on the clutch. After a while, he found the sweet spot and can shift faster than me, smoothly with little clutch time. He is a VERY good driver, so it is just getting used to the hardware you're using.
I think one of the problems is that a stock clutch, with pill, doesn't move as quick as we do. I can definitely feel almost a delay in engagement/disengagement. I need to get rid of the pill and get a SS line and report back results.
Old May 12, 2008 | 09:45 AM
  #34
booster9's Avatar
not using ur body
my b. thats how i was taught, and thats what i thought it was called.. dosnt really matter what its called.
and to the guy that said he ran 12psi on his integra.. well one thing, you musta been built, because i have NEVER heard of a reliable 12psi stock motor. kaboom.. butt you must admit. driving a boosted honda for a DD is not fun. unless you dont take care of it then it wont last very long thats what ive learned in my turbo honda experiences
Old May 12, 2008 | 10:41 AM
  #35
philevo's Avatar
Coming from a honda myself I realized driving my evo like a honda was bad. All my friends have eclipses and evos and the told me to "shift fast NOT hard!"
Old May 12, 2008 | 10:51 AM
  #36
PHDoc19's Avatar
A buddy of mine used to drive his car like that. His second TC was just put to rest in a shallow grave. The bad thing about it is he can't figure out how its happening.
Old May 12, 2008 | 12:33 PM
  #37
booster9's Avatar
lol well someone needs to tell him whats up
Old May 12, 2008 | 01:00 PM
  #38
PSI NRG's Avatar
I would get the clunking noise when I would really shift hard. I mostly noticed it when I let the clutch out fast. Its not good for the rear diff or the drive train at all. The key to driving an evo is to let the clutch out quickly and smoothly. As for the launching you dont ever want to just dump the clutch you will eventually kill your stock clutch or break something. The best way to launch an evo is get on the 2 step slip it a little until it engauges and then let it out quickly and smoothly like you would shift from 1st to 2nd.
Old May 12, 2008 | 01:10 PM
  #39
booster9's Avatar
newbie question.. i seen alot about this "2 step" but i cant seem to find anything about what it is, or how you do it, when i search. sorry if its been covered and i missed it
Old May 12, 2008 | 01:18 PM
  #40
StiEATSevo's Avatar
Thats so weird that it would do it so violently. Really your transfercase can go out just by shifting? I never have that problem in my Sti.
Old May 12, 2008 | 01:26 PM
  #41
booster9's Avatar
thats weird.. someone on here says their sti does it too. maybe you dont know how to drive it the wrong way! which is a good thing lol
Old May 12, 2008 | 01:35 PM
  #42
StiEATSevo's Avatar
Maybe they are Easier to drive than evos. OR maybe they are for noobs who cant handle an evo.
Old May 12, 2008 | 01:39 PM
  #43
ambystom01's Avatar
Any AWD car will do it if you shift too hard. I think my car has done it once and it scared the crap out of me.
Old May 12, 2008 | 01:48 PM
  #44
booster9's Avatar
yeah i was test driving it, i thought the whole rear diff came out. i thought i broke it
Old May 12, 2008 | 01:59 PM
  #45
tweakdsm's Avatar
If yougun it from first gear, and try to shift it to 2nd quicky? evo hate that, because you put alot of load on the trans, (maybe im wrong) well either you launch the car or go smooth to 2nd gear otherwise it might grind. I dont see any problems gonig from 2nd to 3rd fast and from 3rd to 4th fast and ok from 4th to 5th. thats my expirience, yeah evo is no honda sry. First you need to drive the car for couple miles before you can even launch the car and feel the shifts, gl buying an evo.
btw that bang was the rear diff.. it means you did relase the clutch , while still holding the gas pedal.
