Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Shifting an evo correctly. ????
Old May 12, 2008 | 04:47 PM
  #46
Oki Panoki's Avatar
Originally Posted by booster9
lol well actually its barley pushing in the clutch, barley letting go of the gas, and using your body to shif. (leaning into it and gridinging the gears intoeachother)
o lord please dont do this! take it easy why would u want to shred the synchros like that o and if you care about launching it, try to slip it instead of dump for the same reason as shifting, its gonna put alot more shock to the tc and whatnot
Old May 12, 2008 | 05:15 PM
  #47
importjake00's Avatar
2step is a two step process. lol.
First step- Be totally stopped on a level surface and be in 1st gear, then rev to your limit point (5-6500k, depends on the tune) with the clutch in.
Second step- Either slip the clutch (let out until you feel it engaging) or dump the clutch (totally let go of her).
and boom shockalocka you go a launch!
Dumping the clutch is terrible on the car, and im sure you can guess why.
does that clear the 2step up for you?
Old May 12, 2008 | 05:23 PM
  #48
Trail Slide's Avatar
its your rear, most AWD cars do it ... on that note, if you power shifted my AWD car i would of punched you in the face
Old May 12, 2008 | 06:23 PM
  #49
Oki Panoki's Avatar
okay for a while here i thought i was the only one who cared about my car, i would never let anyone drive my car hard and even consider doing something like this
Old May 13, 2008 | 05:14 AM
  #50
booster9's Avatar
that helped alot! thanks
so its better for the car when you slip the clutch in 2step?
Old May 13, 2008 | 09:06 AM
  #51
most would agree so.
Old May 13, 2008 | 01:04 PM
  #52
MrJdmJimi's Avatar
just rev it to 8k and dump it ....
no what i do is my 2step is at 6500rpm i build about 14-15 psi slowly slip till feel a little grap and then dump it smoothh though , not like a honda running of the limiter..(the red area on the gauge)..
couple or even one wrong launch and poof there go's the drivetrain .. my 1st clutch 3000 miles
Old May 13, 2008 | 03:26 PM
  #53
booster9's Avatar
aiightt, ill be careful then
Old May 13, 2008 | 06:54 PM
  #54
XIEvolutionIX's Avatar
double clutching is a down shifting technique, you never use it when you up shift because you wont need to match revs unless you have a very very slow hand. Double clutching from say 4th to 3rd is 4th-clutch in-neutral-clutch out-rev-clutch in-3rd-clutch out. what it does is when you let the clutch out in neutral and rev you get the gears spinning at the same speed as the engine perfectly, it reduces a rear to front weight transfer which can throw of the balance of the car during turn in.
Old May 13, 2008 | 07:38 PM
  #55
MrJdmJimi's Avatar
sorry forgot to mention i think i have 13,000 mile now ..tomorrow new clutch (exedy twin) and new transmission (shep??) just because it grinds in 3rd & 5th ..
im learning the hard way "NOT to drive it like a HONDA".. lets just say about $7,000 in the drivetrain..im going to learn how to shift it smoother ...
im just waiting for the death whine ..anyday
Old May 13, 2008 | 09:03 PM
  #56
booster9's Avatar
ouchhh
i have another question... if im crusin in 4th, and need to drop gears into 2nd.. is there anyway to do that other than just shifting it down? is it bad??
cause with hondas, you can be in 4th, and drop and floor it... do i need to double clutch to do that?
Old May 14, 2008 | 02:38 PM
  #57
MrJdmJimi's Avatar
well i would just drop it down one gear at a time..4-3-2..untill i got to the gear i wanted ....Thats me
Old May 14, 2008 | 07:22 PM
  #58
mpevo8's Avatar
ouchhh
You can rev match into any gear. The way i do it is im cruising in 4th gear and i need to get to 3rd gear. While cruising i push the clutch in with a "blip" of the throttle and drop it quickly to the lower gear.
Throttle (cruising)- Clutch in - Blip throttle - Put in lower gear - drop clutch quickly.
Try "Clutch in and Blip Throttle" at the same time.
it may be difficult at first. be sure not to use to much throttle hence the "blip".
I'll make a video of it sometime this week.
not my video but you get the idea. http://youtube.com/watch?v=G772mJSYnw8&feature=related
Old May 31, 2008 | 05:38 PM
  #59
huevosrancheros's Avatar
Originally Posted by EvoHung
No, I believe double clutching is when you match your revs with mph. Power shifting is when you mash the pedal to the metal and shift without letting go of the gas.
actually powershifting is what the oldschool muscle heads used to do. You shift without using the clutch. Just bang away and shift into gear. Double cluthing is when you keep your foot on gas on all shifts(What honda guys do)
These two terms get confused all the time. It seems like our generation(20 yr olds) know double clutching to be powershifting. I get yelled at by the muscle heads all the time about powershifting.
JDMevoBOOST
Driving Techniques
24
Oct 24, 2010 08:30 PM
awdftw
Nov 5, 2009 11:31 AM
leonard_shelby
23
Mar 31, 2008 04:57 PM
turboguy
Oct 4, 2007 08:27 PM
donmeca2020
Jun 29, 2005 05:47 PM
