Tach or shift light install issues / Help
So, I order a shift light from http://www.raptorperformance.com/ .
Finally its sat, and I have some time to kill.
3 wires, not really rocket science.
Connect pwr/ gnd/ tac signal (ping 89 on the ECU) - http://www.roadraceengineering.com/e...-ecuwiring.htm
no go, shift light never kicks in (had it set for 2500RPM or something just to test)
check the shift light settings, setup 1000(2) 100(5) for a 2 cyl ( 2 coils )
then I tried a 1 cyl , 4 cyl, 8 cyl .. ( hahahaha)
No go, no shift light
also tried ECU pin 58 for tach signal.
Sound like a bad shift light ? all POST's show the light is okay.
Thanks
Thanks
I went directly to the one of the wires that plugs to a coil. If you're interested in hooking it up that way let me know and i'll go and lift the coil cover and check which wire it was....
I'm not sure what pin it is (I was at the time), but my turbo timer is tapped in to the crank position sensor. One of the turbo timer threads discusses the issue (this one, I think: https://www.evolutionm.net/forums/sh...+timer+install).
yea, I used a multimeter on wire 58 and 89 (hahahah dunno what I was really looking for) .. seemed like 58 had less of a voltage increase then 89, but neither of them work w/ the tach
Originally Posted by leonard_shelby
through the firewall / directly to the coil pack ?
