Tach or shift light install issues / Help
Old Mar 29, 2008 | 05:27 PM
Jeeperjunior's Avatar
Hey!!! I know this is an old thread but I am having the exact same problems. Same light everything.... Does anyone know what could be going wrong? I have the light wired to the medium green wire with a white stripe. (pin 58) and when I start my car the light shows that my settings are for a 4 cyl and set at 3000 (just for testing) but then the light never comes on so I need a different rpm wire. I was thinking the one from the coil pack maybe? HELP!!!!
Old Mar 29, 2008 | 05:47 PM
Anybody? There are a lot of people in this forum. No help at all?
Old Mar 29, 2008 | 06:06 PM
ant_turbo's Avatar
On my evo9 it's the middle plug I know it;s the green wire or grenn/white.. Are evo8/9 ecu wire same color,,,I can snap a pic for you,,,,,
Old Mar 29, 2008 | 06:16 PM
Yea I used the green wire with a white stripe........ That is why I'm so confused.
Old Mar 30, 2008 | 10:13 AM
Bump..... Still lost. Need help!
Old Mar 30, 2008 | 11:25 AM
cssaddictm4's Avatar
Do you have the correct Cylinder selection? I am looking at my install instructions ATM. Per the Raptor site it looks like you have to connect it to the negative side of the coil pack, although I have mine pined to #45 on the EMS.
Old Mar 30, 2008 | 01:07 PM
ant_turbo's Avatar
Hey when you turn on the ign does the light flash once?? Check your ground and power wires!! You might have a bad connection,,Wire straight to the battery just to make sure you have a good connection!!! If nothing works then youj have a bad shiftlight,,,,, I bought this shift light http://www.harlan-engineering.com/st...hiftlight.html
Old Mar 30, 2008 | 09:33 PM
A direct connection to the battery is a very bad idea as it is not fused...
Old Mar 31, 2008 | 04:57 PM
The light comes on and flashes at me to indicate the current settings. I hooked the positive and negative up to my boost controller. Does the negative need to be on the coil? I thought that was the whole point of pin 58. I'm up for anything. Keep the ideas coming.
GSX_TO_EVO
Dec 21, 2016 07:20 PM
Nimblestix
Oct 10, 2016 07:51 AM
Fourced4cyl
For Sale - Part Outs
Jan 16, 2012 08:27 PM
D420mac
Evo X How Tos / Installations
Jan 28, 2011 04:09 PM
RIPPMODS
Lancer Aftermarket Forced Induction Tech
169
Apr 4, 2004 09:09 PM
