Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
heel toe shifting
Old Apr 12, 2009 | 04:33 PM
tenaciousd199's Avatar
heel toe shifting
could someone give me a few pointers on this? i've been practicing and whenever i "blip" the throttle to downshift i have problems keeping the braking steady and not following the throttle
thanks
Old Apr 12, 2009 | 04:53 PM
hksevoix's Avatar
Follow it through with a more relaxed technique, all you're doing is bouncing the throttle while foot is still on the brake following by releasing the clutch as you pop the throttle. Its not really an easy way to explain its more of practice that you'll realize your errors. You don't need complete heel on throttle, just enough foot to give it a good pop, but keep your toe on the brake as needed don't release at the same time as heeling.
Old Apr 14, 2009 | 10:13 PM
MATT@WORKS's Avatar
There's already a pretty in-depth thread about this technique in this section.
Old May 10, 2009 | 07:18 AM
dgrumpys's Avatar
wheres the in depth thread bout heel toe shifting.?
im such a noob. ive been blipping throttle with the edge of my right foot, (as the left is pressing the brake)---- dangerous and crappy, i know, but i read it in some racing article and thought thats how its done...
now im gonna practice doing it correctly
Old May 12, 2009 | 01:26 PM
SoCal Rally's Avatar
While 'heel-toe' is the established name for this technique it is really a misnomer, as generally you use the ball of your foot on the brake, and the right side of your foot to blip the throttle. Blipping the throttle is accomplished by rolling the right side of your foot towards the throttle, while attempting to keep consistent pressure on the ball of your foot for the braking component. It takes practice to be able to keep constant pressure or modulate the braking pressure, while simultaneously bilpping the throttle. Keep practicing, preferably in safe traffic conditions, and you'll get it down eventually.
Note: since the throttle pedal is some distance away from the brake pedal, you will need to have the bottom of your right foot twisted towards the throttle before you try and blip it with the side of your foot, so the angle of your right foot will look a bit like this:
Old May 16, 2009 | 07:00 PM
MikeColangelo's Avatar
It took me a while to get good at it. I learned it driving a Miata.
The best advice I can give you is to practice heel-toe downshifting during normal street driving. Practice, practice, practice ....
Also, once you blip the throttle, be sure to execute the downshift quickly. Be smooth and quick about it.
yellowevo82
10
Mar 17, 2017 06:42 PM
devyn339
Jul 23, 2011 09:54 AM
jamiestsi
Jul 18, 2010 09:10 PM
Noe18
Lancer Aftermarket Forced Induction Tech
May 7, 2009 11:51 PM
mike1023
Northeast Region
Oct 4, 2008 05:36 AM
