Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
View Poll Results: How do you launch?
I drop the clutch.
106
20.99%
I slip the clutch.
399
79.01%
Voters: 505. You may not vote on this poll
How to Launch
Old Apr 18, 2005 | 11:56 PM
  #91
MichaelB145's Avatar
I think that would be true on a RWD car, but an AWD car the wheel spin will benefit you as long as your not all over the place. I actually shaved a little off my 60 ft time just by putting on slimmer tires (225's)
Old Apr 20, 2005 | 10:20 AM
  #92
humpevo311's Avatar
Originally Posted by johnnysixer
no problem. Never thought launching could be used in autocross. Now I understand. I thought you were using your evo for drag racing.
Good luck on enjoying the evo in its intended form of motorsport.
Drag Racing is a motorsport.. a rather large one at that..p.s if mitsu intended for people to autox their cars they wouldnt void warranty's for doing it.
I perfected the 3500-4000 rpm quick slip 1 time since the 6 months I've owned the car.. it seems every mod I do makes the car work different and I have to relearn.. as soon as my leg heals its time to go to the track and see whats up
Old Jun 6, 2005 | 02:12 PM
  #93
importkiller's Avatar
Well this is how I launch my Drag car. I stage then I press the button for the trans brake then put the pedal to the floor and then at about the last yellow I release the button. With my SS I hold the rpms at 3grand then I let the clutch out at a good pace not droping it. Then I hold the front end up in the air for a while. I know you were talking about your evos but I thought id share my techniques.
Old Jun 6, 2005 | 07:56 PM
  #94
evo7racer's Avatar
I just slip the clutch at around 3500rpms. Seems to work jus fine.
Old Aug 11, 2005 | 12:51 AM
  #95
jxn evo 8's Avatar
I try to launch at like 4000rpms. I slip the clutch as I push the gas. If done right you get a good launch and you don't burn the clutch. I prefer to slip the clutch bc I would rather replace the clutch( approx 500 dollars) than replace linkage in the drive train (much more money)
Old Aug 12, 2005 | 10:30 AM
  #96
When you say a good launch....what does that mean? What kind of 60ft times are you running?
Old Oct 13, 2005 | 04:40 PM
  #97
FL_SilverEvo8's Avatar
hey everyone thanks for the great info on this thread. haven't gor to try it yet. but have try 2 lauchs before. and smelled my clutch burn both times. i have try it sence then. but now sence i have read this thread. i think i mgith be able to do it. thanks everyone.
Old Oct 14, 2005 | 09:52 AM
  #98
05WhiteEVO8's Avatar
I use the factory Lunch control, I hold the rev's at 5200 or whatever the 05 lmiit is then start slipping it when the lights are falling then when I feel it grab I drop it and nail the throttle.
Old Nov 5, 2005 | 11:12 AM
  #99
FlameRed05SRT's Avatar
I don't own an EVO but I did launch my friends a couple of times and the best launch I got was probably holding it steady at about 4500 and just giving the clutch a quick slip and mashing it. Got a couple of chirps and it didnt bog, and the clutch didn't burn neither, was in the street so unfortunetely I can't give you guys a 60ft time on that.
Now if we are talking about my SRT then I guess i'm better off rolling it off all the time ****, I wonder if I can fit an EVO drivetrain on my SRT-4 Gotta love AWD
Old Nov 9, 2005 | 06:56 PM
  #100
mov_ovr's Avatar
mostly drop it
Old Dec 13, 2005 | 09:27 PM
  #101
mchuang's Avatar
john from tre says the stock t case can handle 500+ hp if you slip the clutch so I would have to say slip it..
Old Dec 13, 2005 | 11:49 PM
  #102
Cloud's Avatar
Anyone have any tales to tell with a IX?
In mine, the best launch (from what I can tell, the tracks are closed here)
Is bringing it up To around 5.5K and Little slip and dropping it. It takes off, but
You can smell the clutch afterwards, I think 4,500 would be a better option.
Maybe since the IX makes more tq down low.
Then I dropped it at 5,500 and I can wheel spin well into second gear, I think because it was a very cold night, with possible Ice on the road. Any other IX owners out there with their 2 cents?
Old Dec 16, 2005 | 10:00 AM
  #103
Doogie Howser's Avatar
Clutch smell afterwards is NOT a good sign and is a sure way to get your factory clutch replaced pretty quickly if done multiple times.
Old Dec 16, 2005 | 10:01 AM
  #104
Can you post up your time slip so we could see how you did with the factory rev limiter enabled?
Old Dec 16, 2005 | 02:50 PM
  #105
kiddevo's Avatar
slip about 5300rpm
