Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
what is the best way to lauch an evo with an upgraded clutch
Old Jun 13, 2004 | 04:48 PM
redevo58's Avatar
i just go an act clutch and findanza flywheel and i would like to know what is the best way to lauch the evo with this clutch? thanks
Old Jun 13, 2004 | 04:50 PM
NvsEvo's Avatar
6000 rpm....;D
Old Jun 13, 2004 | 04:55 PM
ZeroFrost's Avatar
NO dont dump clutch at 6,000RPM unless you want your car in for a blown tranny. Since you got a better clutch that can hold better and doesnt wear like the piece of crap clutch they tossed in from the factory, now you can slip it a little. Go to about 4,500 RPM pull off of clutch till you feel where its about to let go, thenwhen the green light flash's smoothly lift the clutch while you floor the gas pedal. That should stick you in the seat. you might get some clutch smell, but better that than you car warranty going void cause thats what they will do when you take it in. Cause mitsu has the worst service in the world and i cant wait till they go out of business.
Old Dec 1, 2004 | 09:41 AM
redevo561's Avatar
thanks
Old Dec 10, 2004 | 01:36 AM
plokivos's Avatar
If you dump at 7000 Rpm, it could break the tranny, likely, but with an aftermaket single disk clutch, if you dump at 7000 RPM it could induce wheel spin, which is actually beneficial to tranny, because you're transferring all the power to the wheels spinning and not the tranny.
Old Dec 12, 2004 | 06:36 PM
megatron's Avatar
im thinking bout getting a act street clutch too. but ive heard a lot of great stuff about the twin disk clutches. is the extra $800 worth the twin disk?
Old Dec 12, 2004 | 06:40 PM
feldguy's Avatar
I have the Cusco carbon two disk, I bring it up to 5k and feather the clutch at full throttle. The clutch can handle slipping, so can the tires. The tranny is safer that way, no abrupt surge. If you get clutch chatter (feels like wheel hop) OR wheel hope, pull back or stop completely, those are the real destroyers of trannys and worse T-Cases.
Old Dec 13, 2004 | 11:24 AM
Taimur's Avatar
Always slip it a little bit no matter what clutch otherwise u'll hear a bang
btw I also have the Act with Fidanza and love the way it works and IMO not worth another $400 for a twin.
Old Dec 13, 2004 | 11:29 AM
Jaylenospoolboy's Avatar
If you dump at any RPM you run the risk of breaking teeth on your gears. It's like hitting them with a hammer. Always slip enough to let them touch before letting go.
You get a better launch too if you slip enough to let the boost build.
Old Dec 31, 2004 | 10:26 AM
evosevengsr's Avatar
jus remember that something always has to take the pressure.
better the clutch or tires take it than ur tranny.
once something slips ...it's all good
Discospeed
Jan 20, 2011 07:24 PM
ryno770
Nov 5, 2010 07:19 PM
bamf9se
Jan 8, 2008 10:28 PM
Fp3052
Jan 18, 2007 04:32 PM
jaytengan
Driving Techniques
13
Oct 16, 2006 02:27 AM
