DynoFlash [Visit Site]
HKS EIDS & DynoFlash compatible?!?
Old Sep 23, 2004 | 10:27 PM
go2evo's Avatar
Question HKS EIDS & DynoFlash compatible?!?
i have greddy type s re-circ with open filter. idle is ok, when ac is on the idle gets rough, at idling might drop 500 rpm every 10 sec. recently i want to run that vent to air, i want it LOUDER so i could turn some freaking heads!!!, so i spot the HKS EIDS, just wondering would it interfere with the dynoflash that i had?? anyone with similar setup? i had this bov before the flash, not i flashed it, if i add the HKS EIDS, would it mess up anything because the EIDS is going to be plugged into the ECU...please reply
Old Sep 23, 2004 | 10:46 PM
DynoFlash's Avatar
You can use that HKS unit with your Dyno Flash
Old Sep 24, 2004 | 10:27 AM
memo3's Avatar
I was wondering about the same question.
Thanks
Old Sep 24, 2004 | 09:28 PM
go2evo's Avatar
thanks al for letting me know, i just ordered the HKS EIDS $115 including tax, pretty good, anyway i'll let you guys know once i installed it. i will have my bov vent to air instead of recirc + intake. i'll let you guys know can't wait
Old Sep 25, 2004 | 10:41 AM
kvcycle's Avatar
I have a custom tuned Dyno Flash and the HKS EIDS and no problems. I haven't stalled once since I installed the EIDS. It is a good investment if you like the "woosh" sound!
Old Sep 25, 2004 | 11:25 AM
Doug@WGP's Avatar
Will the EIDS and a VTA BOV work with any dynoflash? or just a custom tuned one?
Old Sep 25, 2004 | 12:21 PM
DynoFlash's Avatar
any dyno flash
However - I seriously do not recomend or suggest VTA BOV's
Old Sep 26, 2004 | 05:41 PM
go2evo's Avatar
why? if we use the EIDS to solve the stalling and idling problem, what else is bad?
Old Sep 26, 2004 | 05:45 PM
Doug@WGP's Avatar
Good Q... hey Go2... do you have any sound clips of your setup? I want to go Type S w/ the EIDS
Old Sep 26, 2004 | 07:15 PM
EvoRicer's Avatar
Hey you guys having any problems with your car stuttering in the mornings on cold starts?
Old Sep 27, 2004 | 10:59 AM
go2evo's Avatar
no problem what so ever, mine is recir, when it's really hot and you turn on the ac, then there's some idling issue, but not to a point that will stall the car, but i want to vent to air, it's loud enough to let you hear it, but not loud enough to turn people's head, that **** me off.
Old Sep 28, 2004 | 11:02 PM
go2evo's Avatar
al, i need you to educate me , if EIDS solved the idle problem, what is bad?
