DynoFlash and Boost controller. How fast?
I want to keep my car relatively stock. My freind suggested I get a boost controller and DynoFlash. How much of a gain will I get? Will I get into the 12"s?
Car is bone stock now.
Thanks.
_____________
Rally Red EVOVIII
Thanks.
_____________
Rally Red EVOVIII
You will get 20-30whp and a substantial increase in torque througout the power band with a boost controller set at 19-20psi with a base Dynoflash on a stock motor.
As for getting in the 12's....You must know your baseline first. If you go out to the track and run low 13's on your stock Evo, then yes' you'll hit 12's with the flash and increased boost.
But if your hitting high 13's then... No.
Any which way . You'll definatelly love it after you get flashed.
The biggest help of those mods (besides HP) is that the boost won't drop @ high RPMs, so you'll hold it all the way through the 1/4. I agree with Nad1370's thoughts, and I'd say if you're a good dragger (especially when it comes to the launch), you should be able to do it.
