DynoFlash [Visit Site]
ecu removal and sending
Old Dec 9, 2004 | 06:57 PM
steveevo8's Avatar
umm yeah idk fi this is a type-o but on your last step it says insure for 800 dollars lol hahahaha is this a joke? or do you mean 80??? here look
# Put your car in a safe location where you can leave it for two days
# Remove negative battery terminal - 10 mm
# Open glove box
# There is a plastic tab on the back left hand side you push into the glove box
# Slightly bend the right wall of the glove box inward as you swing it outwards and the right hand plastic tab will clear the dash
# The glove box door swings down and the hinges lift off the dash
# Remove the plastic trim piece under the ECU covering the wiring - it just pulls off towards you
# Take off 3, 10mm bolts holding ECU - lower ECU
# Pull out plugs from ECU - DO NOT pull on wires - pull carefully by the plugs
# Wrap ECU in plastic and cushion in box - insure for $800
Old Dec 9, 2004 | 07:05 PM
GottaGoFaster's Avatar
If your ECU gets damaged or lost in transit and the package is not insured....then what? You think an ECU is $80?
Old Dec 9, 2004 | 07:06 PM
JTB's Avatar
JTB
Buying a used ECU is not too expensive. A new one from Mitsu is probably around $800.
Good luck finding one for $80 used.
Old Dec 9, 2004 | 07:20 PM
steveevo8's Avatar
yeah but insuring it is 800 dollars???!!! thats a tad redic... do you even get your money back if nothing happens?
Old Dec 9, 2004 | 11:45 PM
TC4G63's Avatar
Wink
Steve, that just means when they ask you at FedEX or UPS if you want to insure it, you are going to tell them yes and it's value is $800. The insurance will cost you about $10.
Old Dec 10, 2004 | 12:08 AM
steveevo8's Avatar
oh well jesus i thought you gave htem 800 ****in dollars i was gonan say i'm gonan have a heart attack lol.. thanks for statin that... when they say GIVE 800 dollars i think giving 800 dollars
