DynoFlash [Visit Site]
Al..need some help
Old Dec 28, 2004 | 06:38 AM
SuperchargedGTZ's Avatar
Al..need some help
Just last night my car started to pop a little under hard acceleration in 1st and 2nd gear. It sounds like a backfiring, and it pops like 2 to 3 times under hard acceleration between the rpm range of 4-7K rpm. the car idles like it always has before (weird) and it boosts fine, and the power band feels great. what else should i check. I am going to check the plugs today. Just fyi i have denso iridium IW24. i have had these plugs for about 4 months now and you tuned the car with these plugs in.
any ideas, because i am starting to bug out a little
thanks
PS. your inbox is full
Old Dec 28, 2004 | 07:12 AM
Az3ar's Avatar
thanks
maybe some bad gas??? but I would start with the plugs first.
Old Dec 28, 2004 | 08:10 AM
the gas might be an issue, because i just had filled it with a new tank of gas
but i just want to make sure
i will pull the plugs probably on my lunch break
Old Dec 28, 2004 | 11:21 AM
DynoFlash's Avatar
Try a fresh set of NGK BR7ES and see what that does - sounds like plugs to me
Old Dec 28, 2004 | 12:46 PM
Al,
You dont suggest using the Iridium plugs?
I was going to order these plugs today
Until I get them, I should take it easy on the throttle huh?
Old Dec 28, 2004 | 12:47 PM
DynoFlash's Avatar
What I posted above is what I suggest
I use the BR8ES in ny 667 whp evo
Old Dec 28, 2004 | 05:29 PM
is the gap on the platinum's the same as the iridium's. i went and got a set of the ones you suggested. I am going to install them tonight and do some datalogging and check the timing
i will let you know how it goes
thanks
ed
Old Dec 28, 2004 | 06:30 PM
DynoFlash's Avatar
thanks
ed
Those ones I told you are not plat - they are cheapo copper - I gap them to .26
Old Dec 28, 2004 | 07:53 PM
ok...changed the plugs...the old ones looked good, but after installing the new plugs there was no problem. did some data logging and the lowest the timing got was 11 degrees and not popping
here is some of the info from the data log
"Engine RPM (RPM)","4621.00","4621.00","3488.00","3488.00","34 88.00","2976.00","2976.00","2976.00","1792.00","17 92.00","1792.00","1082.00","1082.00","1082.00","10 82.00","1082.00","1625.00","1625.00","1625.00","47 65.00","4765.00","4765.00","7308.00","7308.00","73 08.00","7308.00","4718.00","4718.00","4718.00"
"Vehicle Speed (MPH)","27.00","27.00","41.00","41.00","41.00","37 .00","37.00","37.00","29.00","29.00","29.00","11.0 0","11.00","11.00","11.00","11.00","0.00","0.00"," 0.00","15.00","15.00","15.00","15.00","52.00","52. 00","52.00","78.00","78.00","78.00"
"Ignition Timing Adv
(°)","39.00","39.00","22.00","22.00","22.00","21.0 0","21.00","21.00","18.00","18.00","18.00","18.00" ,"13.00","13.00","13.00","13.00","16.00","16.00"," 16.00","16.00","11.00","11.00","11.00","36.00","36 .00","36.00","37.00","37.00","37.00"
thanks for the help Al
