DynoFlash [Visit Site]
Ideal adjustment/ How too?
Old Mar 15, 2005 | 02:37 PM
matt55's Avatar
How can I rase the ideal up from 850rpm to 900-950ish ? I adjusted the BISS screw on the T-body and the ECU droped it back down after a while . Any help ?
Thanks
Old Mar 15, 2005 | 02:55 PM
EvoTio's Avatar
I haven't tried to adjust my idle on my Evo yet, but on my 4G63 in my Talon you turn the Biss counter-clockwise to raise the idle. Clockwise to reduce the idle. Try it.
Old Mar 15, 2005 | 02:58 PM
matt55's Avatar
Originally Posted by EvoTio
I haven't tried to adjust my idle on Evo yet, but on my 4G63 in my Talon you turn the Biss counter-clockwise to raise the idle. Clockwise to reduce the idle. Try it.
Yep thats what iam talking about , did it one day and the next it went back down to where it was b4 (850rpms)
Old Mar 15, 2005 | 03:04 PM
EvoTio's Avatar
On my Talon it took several turns to achieve the idle I wanted. It would go up to about 1300 RPM and then settle down to 900-1000 RPM within the next day or so. Again, I am not 100% sure how our Evo's will react.
Old Mar 15, 2005 | 03:38 PM
NYEVO8's Avatar
just a thought but the evo idle might be self correcting from the ecu, maybe.
if you are turning that screw it might be changing the idle temporay, but you might also be changing another setting.
Old Mar 15, 2005 | 05:51 PM
scott88vr6's Avatar
Any other words on this? I would like to know as well.
Old Mar 15, 2005 | 06:19 PM
DynoFlash's Avatar
Thanks
Your idle is bad due to your boost leak and hks bov - resolve those and you will have a fine idle
Old Mar 16, 2005 | 04:53 AM
matt55's Avatar
Yep, since Sunday I did find another leak and fixed it , and replaced the hks unit with the stocker . Waiting for the mr bov's to get off back order . But still would like to raise up the ideal rpm to 900-950ish.
Old Mar 16, 2005 | 06:22 AM
DynoFlash's Avatar
This is one of the reasons why i do NOT recoemdn the 272's on street driven cars.
On your paticular car the idel flash feature was not compatable due to 0300 code issues so I had to remove that and it leaves you with a rough and unpleasant idel.
Fix the boost leaks and your vacume will pick up sluight and the idel will come back to speed - but never be great
Old Mar 16, 2005 | 06:46 AM
matt55's Avatar
So no real way to bump up the ideal with the BISS screw adjment or any other adjustment ? I think Ive got that leak fixed .
playerbanker
Feb 9, 2012 07:08 AM
eyekyu
Aug 27, 2010 07:35 AM
ttnissanzx
Mar 15, 2010 11:14 AM
shh!! sleeping
Mar 1, 2010 04:15 PM
Eggy
Feb 14, 2007 03:23 PM
