Big Announcement for Chicago, IL
June 4, 2005
9:30 a.m. - 11:30 a.m. UncleXSO (Leon B.)
11:30 .m. - 1:30 p.m. Ibanez 126
1:30 p.m. - 3:30 p.m. Redevo1113
3:30 p.m. - 5:30 p.m. eve-slow
5:30 p.m. - 7:30 p.m.
7:30 p.m. - 9:30 p.m. ZoSilverEvo
9:30 p.m. - 11:30 p.m. Healthynine
I have an '03. I have the walboro, cam gears, 272's, TBE w/test pipe. I am currently running the Xede. Couple of questions.
1) Do I need a MBC?
2) Do I need to put the boost line "pill" back in?
3) My Xede has the O2 simulator integrated into it, so I take it I will need an O2 sim for my exhaust correct?
4)Which Mitsubishi misfire flash was it that I needed again?
5) Anything else I should be doing before I come down from Michigan?
1) Do I need a MBC?
Here are my mods al!!!!!!!RNR turbo back exhaust, straight through no cat or resonators, turbo xs high performance boost controler, k&n typhoon short ram intake, and walbro 255 fuel pump. Just curious al, just guessing what kind of gains I might see with your custom tune on a 03 evo gsr with my existing mods. Thanx Francis Orig.
Thanks for the support guys
Friday June 3
7:30 p.m. - 11:30 - p.m. Cosmin and Stan
June 4, 2005
5:30 p.m. - 7:30 p.m. Gas Hero
June 5
10:00 a.m. - 12:00 a.m.
12:00 a.m. - 2:00 p.m.
Friday June 3
June 4, 2005
June 5
Originally Posted by ibanez_926
yea i have a walbro in the mail. I also have a hallman mbc with the incockpit controller (not installed) i got a good deal on it that i couldnt pass up, is that still needed with your new boost flash? i really dont plan on turning my boost up past 20psi
Which short ram intake do you have ?
1) Do I need a MBC?
1) Do I need a MBC?
2 - Yes
3 - you can get that from Buschur Racing or screw your rear o2 sesnor into a spark plug anti-foul tube you can pick up at any auto parts store
4 - You dont need any one - but if you get one - get the latest verion - they just released a new program one month ago
5 - looks good to me
Originally Posted by DynoFlash
There is a thread with directions and photos here on my section of the fourms
The new kits work amazing
Let me say I am fckin happy for you guys!
Pised at myself/luck! I want a custom tune but i am in KC and every time Al is anywhere close to me I either cant make it or out of the country! This su<ks!
For this session I will miss it because I will be out of the country!
So much for my luck!
I guess the bright side is that my car will be at AMS 2 weeks before this!
Oh well!
Just keep up the good work Al!
By the way has anyone had problems getting in 2nd gear at the track?
My 2nd gear does not go in at all over 4000 rpm!
THANKS!
Oh well!
THANKS!
