DynoFlash [Visit Site]
Boost Question
Old May 14, 2005 | 11:27 PM
Randy's Avatar
Boost Question
Ok installed MBC Hallman Pro, set at 20 psi peak but boost drops down to 17 psi, is this normal????????? Al, is there any possible way with the reflash to hold more boost? What are sane boost levels on 93 octane? Maybe I have a boost leak or something? Where to look, thanks for the time.
Randy
Old May 16, 2005 | 09:26 AM
Randy's Avatar
Anyone?
Bump
Old May 16, 2005 | 02:25 PM
DynoFlash's Avatar
Randy
Randy which hallman did you get - pro or RX ? I would suspect a boost leaks If its the pro
Old May 16, 2005 | 02:42 PM
Randy's Avatar
Pro, maybe because the header gasket is not sealing properly? I bought a new gasket and will install it with some gasket grey thingy *lol* the thing that looks like glue or something.
To tell you my problem, the header in the part that is connected to the turbo has a small leak, is that causing the boost drop?
Old May 19, 2005 | 02:10 PM
MAAGJR's Avatar
How did you connected your hallman?
I got mine taking the boost signal directlly from the Intake manifold, THis way is more acurate and dont changes with lossed due to temperature or gas
Also check all your conections and seale them well this was mi first mistake
Old May 20, 2005 | 06:49 AM
Randy's Avatar
FIXED!!!!!!!!!!
Damn header was leaking in 3 different parts, but all is good now and car is a beast muahahahahahh.
See ya today Al.
Randy321
Apr 23, 2016 06:38 AM
alpha
Southeast Region
18
Aug 10, 2008 10:43 PM
Randy
Mar 18, 2007 06:17 PM
Randy
37
Mar 28, 2005 10:58 AM
