DynoFlash [Visit Site]
Tuning Tips for Alcohol Injection??
Old Jun 1, 2005 | 06:55 PM
EvoTech's Avatar
Anyone care to share some tuning tips for alcohol injection? This is for those of us running standalones or piggybacks.
1. Does alcohol injection allow you to run more advance?
2. What PSI should it be set to come on?
3. Straight methanol or denatured alcohol?
Old Jun 1, 2005 | 07:26 PM
tcarretti's Avatar
I'm STILL trying to get this information.......
I've finally gotten the alky kit installed correctly on my car for over a month now and have YET to be able to use it. As it stands, when I turn it on I actually lose power since it makes me run so rich. I'm not comfortable trying to tune my PowerFC on my own so I'm at the mercy of tuners still..... I know, I shouldn't whine about it, it's just that I'm getting a little impatient.
From speaking to a few knowledgeable people.... (David Buscher, Dynoflash and a few others....) the tuning strategy seems to be this:
Set the progressive controller to start spraying at about 18 psi and to max out just over 25psi.
Turn up boost pressure to approximately 25 psi, Tune for between 10.7 and 10.9:1 when the alcohol starts spraying.
You'll then be able to start advancing timing. As far as doing this without a dyno, I think it would probably be dangerous, but I'm sure that there are people out there who have done it.
I don't know enough yet about my standalone to attempt any of this on my own. It's pissing me off, but I'd rather not take a chance of grenading my engine just to say that I did it all on my own.
BTW, I'm using ( or will be using.... it's already in the resevoir....) a 50-50 mix of methanol and distilled water.
Don't know if this was any help, but I figure the more people that share their knowledge, experiences and situations, the sooner this will be more commonplace and SAFER.
Tony
Old Jun 1, 2005 | 11:20 PM
DynoFlash's Avatar
1. - Generally speaking yes - but please realized with extra boost levels there is only a certain level of cylinder pressure which can be run before you reach a point where additional advance does nothing but cause additional stress on your engine. Testing, experience and prudence are the best guide.
2. - Depends on your mods, goals and fuel being used and the characteristics of your alcohol kit.
3. - I run methanol on my car. I tuend a guy with 50% water today who ran just as strong as 100% methanol for his mods. Both will run the same - just depends on your personal preference.
Old Jun 2, 2005 | 04:01 AM
EVO8LTW's Avatar
Is running 50% water just to save money? I can understand running 30% methanol to keep things from being flammable, but why 50:50?
Old Jun 2, 2005 | 05:03 AM
EvoTech's Avatar
Thanks for the response Al. BTW the newer kits do not need to mix klotz with the Alcohol right????
Old Jun 2, 2005 | 07:22 AM
DynoFlash's Avatar
Only the metal pumps need that crap !
Old Jun 2, 2005 | 08:28 AM
EvoTech's Avatar
I went to but Methanol today and I had a choice of 100% pure Methanol or a product called hot shot which has some go fast additives mixed in. This was at a kart shop and the guy told me that at least with the kart engines the hot shot makes more HP. So much so that it is illegal to use in a sanctioned event. I bought the pure methanol but I was interested if anyone knows anything about this product.
Old Jun 2, 2005 | 09:15 AM
umiami80's Avatar
Is any of this better then Pure Race gas, C116? Or is that still the best?
Old Jun 2, 2005 | 03:54 PM
Turbo13's Avatar
Al would a windshield wiper fluid concentrate work that is 98% methanol?
Old Jun 2, 2005 | 06:48 PM
Evoisdream's Avatar
i beleave so considering its probly 98% meth and the rest water?
evoisdream
Old Jun 2, 2005 | 08:29 PM
scherejs's Avatar
^^^lol prolly color your **** blue. seriously though i think i've read where people are using windshield washer fluid.
Old Jun 3, 2005 | 03:53 AM
EVO8LTW's Avatar
evoisdream
Why not just run straight methanol? Is it not available in your area? Or is it a cost thing?
Old Oct 13, 2005 | 08:21 PM
yesevo's Avatar
lets say i got tune for 50/50 methanol/water, can i switch to 100%methanol anytime???
Old Oct 13, 2005 | 08:47 PM
KTT's Avatar
KTT
If ur using a custom tune by Dynofalsh and not tuning urself u should maintain consistancy with what u run. How would the ecu know that you are changing the mixture.... if you don't tell it that u are?
Old Oct 14, 2005 | 08:02 PM
XxBLACKMAMBAxX's Avatar
