DynoFlash [Visit Site]
Al, Need some help before Colorado Tune...
Old Jun 25, 2005 | 11:15 PM
TwStDeVo's Avatar
Al,
i just wanted to ask you a couple of questions before the Colorado Custom Tune.
1) I am looking at ordering a gt35r kit, local people are telling me to expect an additional 20% delay in spool on any turbo compared to sea level, is this true? i will be using 91oct and alky all the time, should i still stick with this turbo?
2) i currently have the 1g bov, im sure it will not hold the amount of boost once i get your custom tune, is the forge bov the best one? what about the turbosmart vta/recir bov? are there any others you would recommend more?
3) would you recommend and ignition system upgrade (hks dl2) if i get the gt35r? what about spark plugs and wires? are 680 injectors going to be enough?
4) are there any other upgrades you would recommend to achieve the most power from a flash (other than stroker/built 2.0, since i cannot find anyone to install either one)?
5) what about drivetrain upgrades? would the exedy twin be the best clutch for me? how much do you sell them for? on top of this i plan on ams bushings and hopefully the quaife lsd (the last batch was recalled). what upgrades do you have?
i apologize for so many questions, i just want to have every power upgrade done before the flash since there would probably be no chance of you comming out again. if there are other upgrades you recommend, please let me know.
Old Jun 25, 2005 | 11:25 PM
chase2000gt's Avatar
While on the high elevation subject, Do you tune differently for higher elevations? I live at 5600 feet, would that make much of a difference?
Old Jun 28, 2005 | 07:35 PM
Turbo13's Avatar
Bump for you!
Old Jun 28, 2005 | 08:01 PM
TwStDeVo's Avatar
Originally Posted by Turbo13
Bump for you!
thanks! seems like its almost impossible to get a hold of Al, atleast im not the only one with this problem.
Old Jun 28, 2005 | 09:28 PM
3240's Avatar
Originally Posted by TwStDeVo
Al,
If your serious about having your engine built let me know. I worked with some guys down in the Springs who do great work. They installed a 2.3L stroker for me. The GT35 will be laggy at altitude vs. sea level but I'd still run it.
Old Jun 29, 2005 | 12:12 AM
TwStDeVo's Avatar
how long would an engine build take, stroker vs 2.0? i want to order my kit today and need to decide which turbo to get. like i said, i will only be running 91oct and alky. so far i have been advised to get the gt3076r since i only have 680 injectors and going to be using a flash, i was told if i had an ems and ran race gas, then the gt35r would be the best.
Evoisdream's Avatar
Bump for al's response.... kinda interesting
Old Jun 29, 2005 | 08:39 AM
TwStDeVo's Avatar
bump
Old Jun 29, 2005 | 08:58 AM
DynoFlash's Avatar
your answers are in the text
Al,
The Gt35R is my personal favorite. With proper tuning the extra lag can be negated
1G bov is plenty unless you want something which looks fancy
Yopu dont need an ingition upgrade with the flash - a plug upgrade is helpful
See the articles on my car in Turbo Magazine - October, 2004 and January 2005
I have access to one used but good condition Exedy Twin carbon with upgraded pressure plate - that is the best clutch
Old Jun 29, 2005 | 09:09 AM
TwStDeVo's Avatar
how much for the clutch? so i should be ok with the 680s? basically need answer to post #6...thanks for replying, i know how busy you must be, i just need to get all these parts before the 16th.
Old Jun 29, 2005 | 09:47 AM
Evoisdream's Avatar
sounds awsome i cant wait for u to get this going!
Old Jun 29, 2005 | 09:58 AM
TwStDeVo's Avatar
looks like its going to be the gt35r, i will pm you about the details for install.
Old Jun 29, 2005 | 10:00 AM
redevo561's Avatar
yeah let us know Thanks
Old Jun 29, 2005 | 10:28 AM
3240's Avatar
Good luck with the GT35 turbo. I just want to make sure that you're not misled to believe that tuning can magically make 5800ft absl act like sea level as far as a turbo goes. I have a standalone in my car and I can't make my turbo spool up here like it does at sea level. I've run my car with an HKS 3240 in Denver and at sea level. The difference in spool time and boost is night and day. No offense to Al, but he's misleading you if you are being led to believe that you'll see the same results up here as those running a GT35 at sea level. Expect lag and realize that there's not much you can do about it especially with a 2.0L. Unless the flash is magic!
Look at sea level GT35 dyno charts and add about 15% to 20% to the spool time. That will give you a realistic idea of what to expect.
Old Jun 29, 2005 | 10:35 AM
TwStDeVo's Avatar
man this is getting to be harder and harder to choose the right turbo and time is running out.
