DynoFlash [Visit Site]
Alcohol Kit?
Old Jul 1, 2005 | 08:52 AM
Randy's Avatar
Alcohol Kit?
Functions, how does it activate, how does it work, when does it activate. If I dont want to run 26 psi will it make more power even at 24 psi? Need to know this info, to see if I get myself one of those, but Im still in the research stage.
Old Jul 1, 2005 | 06:11 PM
The_Predat0r's Avatar
Hey Randy, I received the August Issue of Turbo Magazine and they have an article on the Alcohol Kit on a Evo VIII, with comments from Al Friedman, you should read that article, many questions answer there. Also a few other aticles on Evo parts, Check It Out!
Call me and I will give you the magazine, i mean, you can borrow it but you have to return it! hehehe, you live 2 freakin minutes from me!
Old Jul 1, 2005 | 06:33 PM
eve-slow's Avatar
The system is boost dependant. There are two settings, one low and one high. Set your low one at a psi setting you would like to have a smaller spray and set your high one to where it would spray fully. Very easy to use and is a high quality product on fit and finish.
