DynoFlash [Visit Site]
Vp racing 110 octane kills Flash on car?
Old Aug 5, 2005 | 03:00 PM
kimletrim's Avatar
Registered User
Originally Posted by 4ringturncoat
So true...that's why I could only go 11.90's and evodave 11.50's on a pump gas tune
Nice times, seriously. But I think what I stated above is still true.
Old Aug 5, 2005 | 03:12 PM
4ringturncoat's Avatar
I ran a ton (30) passes with 100, 100 mixed with 110 and 100% 110, and 100% 112 and every pass was within .15's. I would not think adding 110 to a pump tune would cost him 40hp (10hp per tenth is a good rule), maybe, but it seems like something else must have changed. I would call Al's tune "safe" not rich.
Old Aug 5, 2005 | 03:17 PM
Widebandphillip's Avatar
pump gas with alc/meth you mean *_-
Old Aug 5, 2005 | 10:12 PM
NO...read the first part of my sig! No alky, just gas. I diden't add alky till AFTER I put the bigger turbo on. So, I still say 110 did not cost him 40hp.
Old Aug 5, 2005 | 10:52 PM
DragNRacing's Avatar
I agree I ran 12.3 @ 108 and my mph did not change when I ran nearly 100% VP109. It didn't improve over 50/50 93/VP109 but it also definitely didn't lose power/mph. My guess is that something else is amiss. My car even falls off to only 17.5 psi at redline.
Old Aug 6, 2005 | 09:51 AM
justchil's Avatar
Originally Posted by DynoFlash
When you run race gas - turn UP the boost to 24 psi peak - that is how you realize the extra power
Without turning up the boost you will loose power on race gas - slight but a loss
That's what I do and the car is a BEAST on race gas.
Old Oct 21, 2005 | 12:54 AM
hawaiievo's Avatar
what about 104 octane on a 92 octane flash? 22psi 20 by redline. can i just turn up the boost to 24 and race?
Old Oct 21, 2005 | 01:19 AM
warp9's Avatar
I have that flash it does nothing but help, not hurt...There are other factors at play. my 2c
Old Oct 21, 2005 | 07:00 AM
Erik@MIL.SPEC's Avatar
Originally Posted by Ron Jeremy
i did turn up the boost but the weird part was that normally i run 22psi which tappers down to around 19-20 but at the track i was only boosting 18 so i had to crank it up to 22 and when the next day i was boosting 25 so i think it was probably the track conditions Palmdale LACR is at high elevation but i was wondering if the gas was also a factor thanks
It's the elevation. Every car will run lower boost at Palmdale unless you make adjustments. It's not your tune.
Old Oct 21, 2005 | 07:50 AM
C6C6CH3vo's Avatar
Wink
There are many different parameters that can cause the 22 to 20 psi drop and bad time.
But first you must realize that an increase of octane isn't like putting rocket fuel in your car - it actually has less BTU's.
The increase of octane will just allow you to run higher boost w/o detonation and retarded ECU processing.
  1. Check for boost leaks and fix them
  2. Reset your ECU (-batery disc) you might have been using pulled maps prior to the 100 octane, since you only have 91 in cali from lunatic environmentalists - bad gas would be like a piston melting 87 and you would of been racing on retarded ECU memory (which is easily resetable)
Don't worry about the tune, the only way your flash would get killed is by ripping the ECU out of your car and then tossing it accross the street hitting a hippy in the head or taking it to the dealership.
Right before you go down the strip next time reset the battery and try it with 91 @20 psi and then put 100 in another time, turn up the boost, and see what you get.
Old Oct 21, 2005 | 03:26 PM
XxBLACKMAMBAxX's Avatar
Leaded race gas will cause your AFRs to go a full point richer. So if you are tuned at 10.8 on pump gas, which is what my base tune gives me at 20 psi, expect to be at 9.8 on race gas with no boost increase. When I run C16, I turn the boost up to 26 and I have to pull 18% across the board on the AFC, and that still is only in the 11.x AFR range.
