DynoFlash [Visit Site]
hot weather = hard breathing 6000-7000rpm?
Old Aug 22, 2005 | 06:46 AM
Scot's Avatar
My car is 100% stock except mail in dynoflash. I just had the dealer install a new O2 sensor (warranty work).
anyway...the car still seems like it is totally out of breath from 6k-7k on hot days.... but this morning it seemed fine (65F).
is that normal? It has been so long since I had it dynoflashed that I don't remember what it was like stock.
No check engine lights have appeared since the new o2 sensor was installed.
thanks
Old Aug 22, 2005 | 10:20 AM
Scot's Avatar
it didn't do it this morning, but did do it at lunch, so it must be the warmer weather......
I don't remember it doing this last summer, but I can't remember.
should I have it reflashed with the newer V3 boost flash?
Old Aug 22, 2005 | 12:49 PM
bigfishs's Avatar
My car is stock and I notice it runs out of breath at higher rpms when the weather is hot and humid. There is a pretty big difference in my car in the morning drive to work 60 deg and the home drive at 85 deg.
Old Aug 22, 2005 | 01:34 PM
Scot's Avatar
thanks for posting! I guess since I have just that one modification my car is pretty much the same as stock. Wonder if the more modified cars are like that?
Old Aug 22, 2005 | 02:53 PM
DynoFlash's Avatar
I wonder of the dealer installed the 0300 code flash on your ecu when it was in for the warrantty work - ask them if they did that it would erase the flash and I would need to re-install it - free
Old Aug 23, 2005 | 06:48 AM
Scot's Avatar
how do i ask that without drawing some kind of suspicion of modifying the car???
Maybe I will just buy an exhaust and put my drop in filter back in and have you reflash it anyway....
Old Aug 23, 2005 | 07:03 AM
ibanez_926's Avatar
it should tell you on the piece of paper they gave back to you that tells you what they did to your car
Old Aug 23, 2005 | 07:12 AM
4G63>OOOO's Avatar
It's probably pulling timing back from detonation, have you datalogged it yet?
Old Aug 24, 2005 | 06:32 AM
Scot's Avatar
this morning it was 65F and it ran strong to the redline in 1st - 4th gear so it is definately a weather issue..... I am ordering a Works Exhaust muffler (i think) so i will just have Al reflash it for that anyway, and get the update V3 boost and overide the 0300 thing if that is an issue.
Old Aug 24, 2005 | 07:00 AM
d15b7's Avatar
hi scot!
you need water injection, my friend! i run straight water, and even when it is super hot out (90+), with the water on, it just pulls and pulls. i am running al's new V3 flash, without any other form of boost control.... it is my own design water injection kit; i have it set to start spraying at 12 psi, which seems to be perfect for me. if i disarm the water, it doesn't pull as smoothly or as strong up top, especially in this super hot weather we have been having....
since it has been so damn hot, i have been leaving the water armed all the time, and driving "normally" it is using about 1-1/2 to 2 qts of water per tankful gas;
i hope you enjoy that new Works muffler; i was a cheapskate and simply deleted my rear muff and installed a straight piece of pipe; mmmmmm love that burble
see you at beaver run!
todd
Old Aug 24, 2005 | 07:16 AM
NYREDEVO's Avatar
WhaT is the V3 flash??
Old Aug 24, 2005 | 07:30 AM
DynoFlash's Avatar
The V3 is the most advanced boost controlling flash
Old Aug 24, 2005 | 08:19 AM
NYREDEVO's Avatar
Oh right, right I heard you talking about the while back....I didn't know there was a special name for it! What PSI can you control it to? Is this something you can run w/ alky or would you still need to run a mbc?
