DynoFlash [Visit Site]
Al, got question on alky kit before tune
Old Sep 21, 2005 | 05:02 PM
Evil_1's Avatar
Al, I'm in the process of installing the alky kit. Just received it today . My question is that I'll be driving over 300 miles to meet you for a tune for it so do I just run water in the kit in the mean time or run alcohal and crank boost up a bit or just not hook up power until I get there. What do you recommend? 100% alky, 100% meth, or 50/50? Thanks
Old Sep 21, 2005 | 06:08 PM
mooreboost's Avatar
100% alky.
Do not alter boost or turn the kit on until you get there.
Old Sep 21, 2005 | 08:50 PM
Evil_1's Avatar
Originally Posted by mooreboost
100% alky.
Thanks for the advice. So it's ok to have the nozzle and kit all hooked up but just don't put alcohal in tank and not hook up power?
Old Sep 22, 2005 | 08:56 PM
Turbotsiawd96's Avatar
if i was u i would jsut keep the fuse power wire disconnected then just put the fuse in when u get there so that the pump doesnt run with nothing going through it(not saying that this is bad cause i dunno the effects)
Old Sep 23, 2005 | 01:04 PM
hawjdude's Avatar
Man, are you that power hungry man. When you get that alky installed you better go redyno it and give me a test drive.
Old Sep 23, 2005 | 03:13 PM
Deepseadiver's Avatar
I have a question along the same lines.
If you hook everything up, incuding filling it with alky, and having it turned on, and you drove it off boost (keeping the revs under 3000RPM) would it use any alky? Would the alky tank stay full?
If it does, I would say hook it all up before driving there. That way you make sure the system dosent leak, and does its function test as well.
This question is for Al, Do you have any kits left? I am think of installing one before you come to D.C in 11 days.
Old Sep 23, 2005 | 04:31 PM
mikesevo8's Avatar
The SMC kit has 2 adjustable settings - at what psi the pump turns on, and at what psi the pump reaches max pressure.
I have mine set at 14/25. So if you stay under the min. pressure, the kit doesn't spray.
When my low light comes on, I switch my HKS EVC to 'A' which is set to 12psi.
I can drive worry free until I get more alky.
Old Sep 23, 2005 | 05:59 PM
Is the one that Dynoflash sells the SMC kit? or is it the Buschur kit? whats the difference in price?
Old Sep 24, 2005 | 06:01 AM
mikesevo8's Avatar
I believe both kits are made by SMC for each tuner. They will use the same control unit.
Old Sep 25, 2005 | 01:58 AM
Ozzmosis's Avatar
Why do some people mix in water while others go 100% Alky? Is their a benefit either way?
Old Sep 25, 2005 | 09:11 AM
mikesevo8's Avatar
I think it's mainly a cost/performance issue.
Straight alky will reward you with more HP than a mix; using methanol even give more.
The important thing is, whatever mix you decide to use - straight water, washer fluid, alky alone,
alky/water mix, methanol - whatever you get tuned for, you must stick with that choice.
Don't get tuned for washer fluid, then toss in methanol; probably a bad idea.
Old Sep 25, 2005 | 09:48 AM
DynoFlash's Avatar
Good idea
After he checks out the system and sees it working 100% - then just pull the power fuse till you get to me for the tune !
Old Sep 25, 2005 | 10:23 AM
Evil_1's Avatar
Originally Posted by DynoFlash
Good idea
Ha...ha Al, I've already got it figured out. Thanks for the Meth tune yesterday. Heading home was a blast on the highway
Old Sep 25, 2005 | 11:15 AM
Ozzmosis's Avatar
How much is this denatured Alcohol and how easy is it to get? ANyone with a link to this stuff? Cuz if you get tuned with it, what happens when you run out? What about ALKY and Race gas?
Just wondering cuz this looks liek a great setup, thanks
Old Sep 25, 2005 | 11:28 AM
Evil_1's Avatar
$12.00/gallon. Methanol is cheapear but harder to find. You'll have to go to some kind of shop that sells racing fuel.
