DynoFlash [Visit Site]
Less power than before flash
Old Sep 24, 2005 | 07:18 AM
Adam0925's Avatar
Exclamation Less power than before flash
I'm not sure what the problem is because the car seems to be running good. I just got my ECU back on Wednesday and I was very pleased at how I thought the car was running. I took her to the local drag strip last night and I did not have a good night. The best I could muster was a 14.2 at 93mph with a 1.9 60ft. This is significantly slower than when I was stock.
My current mods:
HKS racing suction intake
Walboro fuel pump
MBC
Dynoflash
I expected to be trapping around 104mph or so with times in the low 13's to high 12's. Any ideas.
Old Sep 24, 2005 | 07:21 AM
EvoDan2004's Avatar
maby your cluch is starting to go. even tho you may be making more power you cluch is going to slip a lil more. its a gess so dont hold me to it.
BoostWhore's Avatar
get a full exhaust
Old Sep 24, 2005 | 07:23 AM
Deepseadiver's Avatar
might have a small boost leak??
Old Sep 24, 2005 | 07:27 AM
Vroompsh's Avatar
could be a boost leak, and maybe the clutch..but i think you'd notice the clutch slipping. check all your boost hoses...dude you should have gotten an exhaust before all that stuff
Old Sep 24, 2005 | 07:30 AM
Randy's Avatar
your shifting?
Old Sep 24, 2005 | 07:31 AM
Adam0925's Avatar
Its definately not the clutch. The car only has 3800 pretty conservatively driven miles on it. My exhaust is coming next week. I guess it could be a boost leak. I thought maybe it was the boost controller. Got a new Hallman pro on the way too.
Old Sep 24, 2005 | 07:33 AM
Adam0925's Avatar
Originally Posted by Randy
your shifting?
shifting at 7200rpm. If anything I'm driving better than I was when I was stock. Even without the mods I should have seen some improvement based on driving alone.
Old Sep 24, 2005 | 08:27 AM
kmcconn9's Avatar
yea, I would lean towards a boost leak for sure
Old Sep 24, 2005 | 08:30 AM
Adam0925's Avatar
Would a boost leak really cause that much of a drop in my trap speed? We're talking like 10mph or more lost.
Old Sep 24, 2005 | 08:46 AM
dbdude's Avatar
Do you have a boost gauge?
Old Sep 24, 2005 | 08:49 AM
pyrovice's Avatar
yeah boost leaks can sap pretty much all of your power depending on how bad they are. Haha I've been N/A before when an IC hose popped off and I probably would have trapped around 70 mph...
Old Sep 24, 2005 | 08:50 AM
Adam0925's Avatar
yes...and the boost was a bit on the low side no matter what I did with MBC. I just dont see how a boost leak could cause that big of a loss in power.
Old Sep 24, 2005 | 08:54 AM
matt55's Avatar
Old Sep 24, 2005 | 08:56 AM
pyrovice's Avatar
Originally Posted by matt55
+1
