AMS GT3076 Turbo + Alcohol Kit
Anybody here runs an AMS GT3076 turbo with Al's alcohol kit? On 93 pump gas, what kind of HP/TQ numbers will I be looking at? Would 450whp be possible?
I have 264/272 cams, Forge MBC, ARC intake, Buschur exhaust and downpipe. I'll be upgrading the intercooler and the intercooler pipes when I get the turbo kit as well.
With the TME turbo, I made 334 whp at Pruven. Wondering if the turbo upgrade is worth the $$.
I like Al's flash and would like to keep my car as a daily driver, so no EMS for me.
I have that set up and I have probably 450-475 hp and monster torque...i gotta scan my dyno sheet....but iLL be at pruven next week to see if the cool air can push a lil more power with that setup and increase injector size and amplify ignition
ummmmm...
standalone aem
gt 3076r
272 cams
alky
26 psi
__________________
MONSTER POWER
ummmmm...
standalone aem
gt 3076r
272 cams
alky
26 psi
__________________
MONSTER POWER
Don't know and don't care about dyno numbers but I did just run a 11.54 @ 121.6 on a BR500bb (GT3076), alky, custom flash, 93oct and 26 psi. ALso ran a 11.62 @ 113, I backed out at 1000' b/c I dident want to break 11.49 and get banned. I am pretty sure the car would go hi 30's to low 40's just the way it is now.
Al-Do you have a flash for 280's yet? I am pulling the motor this weekend to do a 35r, 2.3l, and 280's from BR.
im curious about this set up also. i am looking for 450+whp on pump and alky. if anyone else has experience with this set up please post.
Blazedevo781, cant wait to see your dyno results, please post when you get them.
4ringturncoat,
are you going to stay with a flash with your new set up? how did your set up feel? do you think your 1/4 mile times will improve on pump and alky with your new set up? im also considering a 2.3, but not sure if i can do the 35r due to my elevation(6500ft).
4ringturncoat,
4ringturncoat,
4ringturncoat,
It was very fast! Any mid 11 second car is going to be pretty brutal out on the street. I had sevel 7.30 to 7.40 @ 95mph last weekend. I am going to build the car to be almost exceclty like Dan Buschurs car which is going low tens right now. I really think a mid 10.60 to .70 is possible on the stock maf.
Even Dave agreed that with race gas and a more aggressive tune the current set-up could be in the 11.30's so I am more then confidant the new set-up will go 10's.
The good thing with a 3076 is at 26-27psi (which is fine on pump and alky) you are really in the meat of that turbo. I am half tempted to try the stroker AND a 3076 before I go to a 35r. I am pretty sure with a stroker and some good driving a ten is possible out of the 30r. This combo would be super sweet on the street and track. A ten second car that has stock like spooling and pump gas would be pretty nasty.
I had one really good pass last week that I backed out of b/c I was going to go faster then 11.50 and still ran a 11.64 at 112.5 so even in the current combo the turbo easly has an 11.40 in it and with a little more timing/boost I would bet it will run 11.30's. If you go with Daves kit you can get the 30r and then swap to the 35r if you want to.
