DynoFlash [Visit Site]
Case study #127 - Intersting results with MR and no cams with alcohol
Old Dec 13, 2005 | 01:33 PM
Warrtalon's Avatar
Originally Posted by CFaber
Not to hijack, but...
I've thought about doing this same thing. I'm tired of the surge I'm getting with the MR valve. What are your desired results with the change?
I don't have surging problems with the MR DV. It will naturally surge some if I go light throttle in top gear and let off, but that's just natural with a stiff spring. I consider it poor driving on my part if I encounter this, because it usually means I messed up. Anyway, I want to see if the UNOS holds boost any better than the Hallman, first of all. I also want to test out the ratchet feature, because I change my boost a lot due to racing and changes in temp. The Forge BOV is just to see if it holds boost any better on the top end. I will be testing them separately starting with the Forge BOV combined with my Hallman, and then the UNOS with my MR DV. Eventually, I plan to just run both Forge parts daily, but I have to wait on my sponsored parts to show up (got the RS BOV, but waiting on the UNOS).
Old Dec 13, 2005 | 02:02 PM
CFaber's Avatar
thanks for the response! i look forward to hearing your thoughts on each.
Old Dec 13, 2005 | 02:34 PM
Killboy's Avatar
I really like my Forge Type RS and UNOS. I have the RS recirculating with the one-piece piston, and it does flutter just a bit in top gears at low RPM. I have it set as weak as it will go. The RS "kit" I received (ordered straight from Forge) came with the "Stiff" spring, which is only about an inch tall and bare metal. I just got off the phone with Luis at Forge, and he said it should have shipped with the weaker yellow spring, which is about 2 inches tall, so they are sending that to me.
Old Dec 13, 2005 | 02:41 PM
Kee1pride's Avatar
damnit al! you co*k tease.
how dare you tell us about the celeb and then just keep it to your self?
you shouldn't of even brought it up in the first place. now we will all cry and weep like babies ;-;
Old Dec 13, 2005 | 03:56 PM
TURBODAWG's Avatar
The Forge valve will keep your valuable boost from being leaked out. That will keep the charge air cooler. You boost should hold better also above 21 psi. In testing that is where I found the JDM MR bov started to crack open. The Forge UNOS MBC works awesome. It holds rock steady up until the point where it normally starts to taper. The taper is still present, but the boost is as steady up until the taper, that I have ever seen. Strange thing also is that the boost doesnt seem to change as the weather gets colder. Very nice unit.
Brian
Old Dec 13, 2005 | 04:23 PM
ibanez_926's Avatar
I bet Al has never been called that before
Old Dec 13, 2005 | 05:33 PM
DynoFlash's Avatar
The new Forge RS recirc is just amazing guys
You can drive most days on a easy spring setting and then when you wnt crank down the knob and get max performance - a great product
Old Dec 13, 2005 | 09:12 PM
Warrtalon's Avatar
These are the exact things I'm looking for when testing these two items.
Old Dec 13, 2005 | 09:40 PM
bounthai's Avatar
william Hung from american idle!
Old Dec 14, 2005 | 01:43 PM
superz's Avatar
It was probably Shiv
Old Dec 14, 2005 | 02:21 PM
Warrtalon's Avatar
Hey, SuperZ, check it out:
My Pup
Old Dec 14, 2005 | 03:58 PM
Turbo13's Avatar
Hey Al and whoever else can help, what are the differences with the traditional Forge recirc BOV I got from you AL and the new rs?
Old Dec 14, 2005 | 06:15 PM
Killboy's Avatar
Forge makes a ton of different BOVs, but I can tell you the main feature of the RS is it's adjustability. There is a big, ratcheting knob that let's you preload the spring for different setups. It's really the only way to go, especially if you are modifying your car. Here's a direct link to their RS page and you can see all of the others they make there.
Old Dec 15, 2005 | 06:28 AM
8thWonder's Avatar
It really does seem like the consensus is that Forge makes probably the best MBC and BOV right now. I ordered my UNOS yesterday. I'm going to get the RS BOV after Christmas. I'm running the stock BOV now and I just have a feeling it's leaking all over the place.
Old Dec 15, 2005 | 06:50 AM
Warrtalon's Avatar
It's probably not leaking all over the place. Remember that I ran 12.22 on the stock BOV while pushing 23-24psi on race gas with just a cat-back. I know that it does leak at higher boost, but it's not like some total piece of crap that doesn't perform at all. If you aren't pushing more than stock boost, then you aren't being negatively affected by the stock bov that much. However, when you install the MBC and not only raise the boost but remove most of the high-rpm taper, a nice, strong BOV will come in handy.
Btw, I put the Forge RS on, and it works great. Unlike the JDM MR DV, it is adjustable, so that is taking some time to dial in, but this way it allows me to set it to super stiff at the track and then half-way during daily driving so as to eliminate most of the surge in top gear.
