DynoFlash [Visit Site]
question about the mail in flash...
Old Dec 29, 2005 | 10:31 AM
JSYEVO's Avatar
well i got the ttm flash awhile back and was wodnering what the rev limit is set to, i looked on the website and it doesnt really specify. also, is it safe to rev that high often? thanks
Old Dec 29, 2005 | 11:01 AM
Jim_Patterson's Avatar
its 7800 i beleive and search, this has be discussed way too many times.
Old Dec 29, 2005 | 11:23 AM
DizzyTT's Avatar
mine for a custom flash was 7850, but I really wanted it to be 8k, but I forgot to ask Al to busy fixing a boost leak
Old Dec 29, 2005 | 12:57 PM
JSYEVO's Avatar
i did search, couldnt find anything. so is it safe to rev that high a lot?
Old Dec 29, 2005 | 12:59 PM
Warrtalon's Avatar
7800 is default for all Dynoflashes unless otherwise specified by the user. Stock is 7600, so it's a raise of 200rpm. Mine is 8000rpm only by request.
It is certainly safe to rev to 7800. If you've never revved to 7600 on your car, which is the stock rev limiter, then you haven't driven it yet.
Old Dec 29, 2005 | 02:40 PM
walkedu's Avatar
^ Well said
Old Dec 29, 2005 | 03:50 PM
smokedmustang's Avatar
Your flash will cut out before you do dammage to your ride, I ride the revs high quite often, shift at 4-5Krpm. So far, so good.
Old Dec 29, 2005 | 11:04 PM
JSYEVO's Avatar
wow, i always shift at about 7200 lol, im kinda excited now
Old Dec 29, 2005 | 11:08 PM
Warrtalon's Avatar
You should shift at 7200rpm if going for perfect drag times, but if you're just taking one gear all the way out, then go ahead and rev a little higher. Don't go around rapping through the gears while shifting at 7600 every time, though, until you get cams.
Old Dec 30, 2005 | 07:13 AM
flabarm's Avatar
From reading your previous post I thought that you were trying to say that shifting at 7600 was optimal for time, so thanks for clearing that up. It seems like the car loses power after 7k. Any truth to this? I'm so used to honda's gaining power all the way until redline, that it makes me think the evo is slow, although I know it's not.
