DynoFlash [Visit Site]
How many times an ECU can be flashed?
Old Jan 7, 2006 | 06:06 AM
The_Predat0r's Avatar
Hi AL, I am asking this because in Puerto Rico Gadiel is now a Cobb Tuning Accesport Pro Reflash Certified Tuner. Now he can reflash all kind of Subarus. And in the Cobb Tuning Webpage I saw this:
Due to limitations within the ECU's flash memory, one can only successfully reprogram it approximately 100 times. In response to this challenge, our engineers developed a LIMITLESS Map Switching system. This means you can switch between maps as often as you like quickly, easily, and without ever reducing the life of your ECU's flash memory.
This is the Accessport: http://cobbtuning.com/legacy/accessport.html
Also Gadiel said thats the reason why the tuners do very little passes when reflashing. Is that true in the Evos too? I didnt knew that. Just curious.
Old Jan 7, 2006 | 06:22 AM
smokedmustang's Avatar
Are you going to change parts that need a flash more than 100 times? that seems like enough for me! (100X)
Old Jan 7, 2006 | 06:29 AM
ThunderOZ's Avatar
mores usually better right? plus u never knw i think 100 is overkill but it should be enough
Old Jan 7, 2006 | 01:15 PM
DynoFlash's Avatar
I have about 400 flashes on my own stock evo ecu
The specs on the chip warranty that it is good for 100 flashes
I dont think any customers have gone over that
