DynoFlash [Visit Site]
Thanks Al...
Old Jan 15, 2006 | 08:33 PM
Most-Wanted's Avatar
Rnm - we should try to meet up again sometime.
MANGOOK- How's the car? Any passes yet?
Old Jan 15, 2006 | 09:22 PM
IE Evo's Avatar
Heh, no, not 330-358whp. More like 280-290whp right now. I think you meant to say BHP? I'm at 300whp right now in 12.26@110 mode. Great driving, though. I look forward to the boost being raised up to 21-22psi.
Warrtalon ur 12.2 at 110 mph is very impressive. Do u no lift shift? Most decent drivers need 320 whp to pull off 12.2 at 110 mph. So I really believe his car is closer to 300 whp and urs is at least 20 more.
Old Jan 16, 2006 | 07:34 AM
3000ways's Avatar
Originally Posted by Most-Wanted
warrtalon was right again. The formula is called the Patrick Hale formula and I stand corrected. I really hate to be wrong, but you were right. This is from the formula index page-"hp" is the peak engine power output at the crankshaft in horsepower, and
"weight" is the the total weight of the vehicle (with driver) in pounds.
At least I can admit it Here is the full details on the run. Still good for 18psi I think.
60' 1.777
330 5.175
1/8 8.013
mph 85.17
1000 10.476
1/4 12.547
mph 108.49
I honestly believe that your car could trap 109MPH at only 18PSI if you kept at it. But why would you do that? I'm very interested to see what you will run with more boost, I'm taking a guess here, and I believe you if you keep at it and run 23-24PSI it is possible that you may hit 11s with mods you have on your IX. I am comparing you to another evom.net member who had a similiar problem but for different reasons as you.
This is one of his time slips, notice that it is very similiar to your run-
RT .027
60 1.70
330 5.16
1/8 8.00
mph 85.08
1000 10.48
1/4 12.55
mph 108.94
His car should have been faster, just like yours but both of you were lacking enough boost. Your car was only boosting 18PSI because you were not fully prepared. His car was boosting 25PSI but his car was most likely suffering a minor boost leak. I do not think he ever addressed the problem of a possible boost leak (reading his later threads), but still installed a Alcohol Kit and ran 24.5PSI, he would later run a-
60' 1.655
330 4.909
1/8 7.601
Mph 90.49
1000 9.900
1/4 11.841
Mph 116.05
Now I believed the Alcohol Kit helped, but he still was not holding boost up to the full potential and his Alcohol Kit with a minor boost leak in my opinion would be comparable to your stock turbo boosting 24PSI.
I don't know this is just my theory, I could be totally wrong and you run a 12.3 @110MPH with more boost, so I guess we will just wait and see.
Old Jan 16, 2006 | 10:40 AM
Warrtalon's Avatar
No problem. Minor misunderstanding. The best part about this disagreement is that we weren't arguing DYNO results that had no proof from the track, but rather arguing ESTIMATED hp based off REAL RESULTS. I would MUCH RATHER have the real live 12.5@108.5 than a dyno result that makes me think I can get a 12.5@108.5. I prefer to hit the track to show actual results, then hit the dyno to show what those results translate to...you've already done the same thing.
Old Jan 16, 2006 | 10:41 AM
Warrtalon's Avatar
I no-lift the 3-4, and I half-lift the 2-3 (50% TPS), but the 1-2 is a standard, full lift snap shift.
Old Jan 16, 2006 | 01:03 PM
Warrtalon- I may go again on Wednesday. I'll turn it up to 21psi and see what happens.
3000ways- I'm curious what more boost will do also. I don't think it will be much. I'm thinking 12.3/12.4 at 110 is very realistic though.
Old Jan 18, 2006 | 03:05 PM
MANGOOK's Avatar
The car is running great I havent gotten to the track yet but I just got my clutch and everything installed so I will be going when I am not working.
Old Jan 19, 2006 | 01:09 PM
Here's the update Al, the car is running great!
Buschur/dynoflash Ix Goes 12.0
Well, like I thought, the car just needed a little more boost. I ran 20-21psi all night and the car is an animal. Here are the numbers. Many thanks to the Buschur guys who build great parts and to Al for the flash.
60' 1.74
330' 5.07
1/8 7.86
mph 86.77
1000 10.269
1/4 12.27
mph 111.98
60' 1.77
330' 5.05
1/8 7.80
mph 88.88
1000 10.17
1/4 12.16
mph 112.78
60' 1.73
330' 5.00
1/8 7.74
mph 88.83
1000 10.10
1/4 12.09
mph 112.00
Mod list is Buschur TBE, Buschur MA intake/filter kit, Buschur upper I/C pipe w/ 1G BOV, and of course the Dynoflash. Wonder if there are any Vishnu cars running 12.0 w/ intake, exhaust, and a flash???
Old Jan 19, 2006 | 01:24 PM
Warrtalon's Avatar
Btw, now you're probably around 330-340whp. You would have trapped 113+ probably with a higher rev limiter. Are you sure it was raised above stock (7600)?
Old Jan 19, 2006 | 03:08 PM
I'll have to check it, but it should've been switched.
Old Jan 19, 2006 | 04:18 PM
DynoFlash's Avatar
DAMM !!!!!!!!!!!!!!!!!!!!!!!!
Almost 11's already !!!!!!!!!!!!!!!
Way to go man
(PS - and to think you hae the identical tune to the guy with the BR Stage II in cali that Vishnu re-tuned after it had no power)
BTW - for those interested the base flash on this car is IDENTICAL same as the BR350 package which Buschur sells
This tune was developed over a 3 day period at Buschur Racing this December
Wild to think it has 11 second potential on pump gas
PPS - sorry about the rev limiter - its not raised on the BR350 as it is covered by a warranty - next time I am in Florida I will be happy to correct it for you
60' 1.74
330' 5.07
1/8 7.86
mph 86.77
1000 10.269
1/4 12.27
mph 111.98
60' 1.77
330' 5.05
1/8 7.80
mph 88.88
1000 10.17
1/4 12.16
mph 112.78
60' 1.73
330' 5.00
1/8 7.74
mph 88.83
1000 10.10
1/4 12.09
mph 112.00
Old Jan 19, 2006 | 08:44 PM
And to think it would've run 11's brings tears to my eyes No problem, can't complain with
12.0's. See ya on your next trip.
Old Jan 20, 2006 | 06:33 PM
slowwevo's Avatar
Oh Yea!!
