DynoFlash [Visit Site]
continue with p0300
Old Jan 16, 2006 | 01:22 PM
tequila083's Avatar
continue with p0300
I reflash my ecu for the second time to resolve p0300 and after 3k milles again i have the p0300 dayly before the second reflash i install NGKBPR7EIX to resolve this with no luck. But know i can feel the misfire in 5 gear about 60 mph. I have to remove the foot on the pedal to cut the misfire and then accelerate again an the misfire gone.
Which gap do i need to adjust the plugs i install them with the factory gap. Do you think i must replece the plug wires?
Old Jan 17, 2006 | 07:25 AM
defeated26's Avatar
i really don't think it's your plugs or wires. it's like the ECU thinks there is a misfire and goes into some "safe" mode to avoid damaging the car, then when you let off the gas it senses everything is ok and lets you accelerate as normal. I have had this problem forever, it's just a mystery to me.
Old Jan 17, 2006 | 08:07 AM
evocanival's Avatar
yeah i got the same exact peroblem, dont know what it is. My plugs are gapped to .27 so i dont know
Old Jan 17, 2006 | 08:42 AM
03evospeed's Avatar
www.vishnutuning.com has a c-reader that you just leave plugged. It'll clear the code when it miss-fires. This is the only way I can drive my car with out wanting to drive it into a tree.
Old Jan 17, 2006 | 09:00 AM
Creamo3's Avatar
Most if not all of my misfire issues went away when I installed a HKS DLI2, otherwise I was in the same boat as you before. I am running my plug gap around .28
Old Jan 17, 2006 | 10:02 AM
defeated26's Avatar
what is that? searched google and the HKS site and still can't figure out what you are talking about.
edit: found out what it was, DLI II is what i had to search for. A twim power ignition amplifier. WOW $535, no thanx.
Old Jan 17, 2006 | 11:02 AM
Creamo3's Avatar
Never said it was a cheap fix
Old Jan 17, 2006 | 01:50 PM
tequila083's Avatar
A went to a mitsu dealer to order a set of spark plug cables to verify if i can resolve the problem with the misfire they told me that it could be a reason for the misfire.
They also offer to update my ecu with the p0300 fix. I think it can erase my dynoflash with that update what do you think. I really want to remove that problem.
Old Jan 17, 2006 | 02:35 PM
thatsMR2u's Avatar
yes it will erase your dynoflash, you should have gotten that update before u got re-flashed again- PM AL you should be able to work something out
Old Jan 17, 2006 | 03:14 PM
DynoFlash's Avatar
Get the newest 0300 code update from the dealer and then send back the ecu for a re-install of your original dyno flash with a list of mods and $50 for shipping and handling
As an alternative - you can just plug in a CREADER into your obdii plug and it will prevent this problem - you can but them on ebay very cheaply
Old Jan 17, 2006 | 03:26 PM
Curt@MrLed's Avatar
Former Vendor
do the 05's have the newest flash.. or does that have to be updated.. sorry havent read up much on this subject..
Old Jan 17, 2006 | 04:50 PM
SilverShadow03's Avatar
Question
I have had the same problem ever since I tuned my car......i have a base Vishnu Flash with custom dyno tune...if I have the dealer reflash with the newest p0300 fix, it'll wipe out my tune/flash. I'm not happy to have to pay for another dyno tune, if I were to take this route.
I still am hesitant the new p0300 fix (however new this really is) will actually FIX my cel and problem and engine sputtering around 60 mph (actually anywhere between 3000 RPM & 3600 RPM). It doesn't sputter thru this whole range....just once somewhere in between this range. It NEVER stutters during WOT!
I'll keep reading hoping for a cheap solution without wiping out my tune!
*I am VERY Happy with my Vishnu Tune! Just so you don't think I'm blaming them in any way...cuase I'm not!
Old Jan 18, 2006 | 10:15 AM
xme's Avatar
xme
hmmm very interesting .. i guess i would have to go to my dealer to have this issue fixed before heading to see AL for my upgrades / reflash .. ?
Old Feb 4, 2006 | 07:07 PM
tequila083's Avatar
Finally p0300 gone. I took mitsubishi p0300 flash and all the problems gone misfire and the cel. I will test my car for now before send the ecu to reflash with dynoflash. I feel my car stronger on low rpm. I think they do something with the maps.
Old Feb 5, 2006 | 08:03 AM
dbdude's Avatar
Al, i thought you had a po300 fix in your flashes. Is this true? Now im scared to get a tune cuz my car is an 03. I have had my car for 12k miles and its been custome tuned before. I have not had that code ever.
